223 Flywheel on a 292?
Old Aug 28, 2007 | 04:35 PM
60FordF100's Avatar
60FordF100
Hi,
I am taking out a bad 223 and installing a 292 into my 60 F100, 3 speed. The 223 flywheel bolts up to the 292 crank and I want to know if it can be used or if I will encounter other problems.
Thanks!
Gary
Old Aug 28, 2007 | 10:11 PM
46yblock's Avatar
46yblock
Gary, wish I could answer your question directly, but cant. However, if all 6 of the bolts match up, and the same number of teeth are on the 223 and Y flywheel, it has to be the same flywheel, Dont remember for sure but think the Y's are 153 teeth. If someone else hasnt given the tooth count already, I'll count them out and post the result tomorrow.
Old Aug 28, 2007 | 10:13 PM
46yblock's Avatar
46yblock
Duplicate post erased
Old Aug 29, 2007 | 07:26 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking Flywheel Interchange
According to Hollanders interchange manual Y block and 223 6cyl
flywheels do interchange . Bellhousings do not!
Have A Good Day-------Hotwrench
Old Aug 29, 2007 | 02:04 PM
312's Avatar
312
same thing.
Old Aug 29, 2007 | 04:43 PM
60FordF100's Avatar
60FordF100
Thanks folks. That will save me some time and money. I did notice that the 223 flywheel is only drilled for a 10 inch clutch and I read somewhere that the 292 had a 10.5 to 11 inch clutch. Since I am not going to be hauling anything, I suppose the 10 inch will be ok. Possibly I can get it drilled for a 10.5 inch clutch, looks like it is big enough.
Thanks again!!
7.3stroker2
20
Oct 24, 2015 10:39 PM
OldFords
Apr 29, 2015 07:09 PM
Cazman1955
Apr 16, 2015 06:28 PM
Damifiknow
Nov 15, 2013 08:03 AM
58AZF100
Feb 24, 2011 10:18 PM
