Egt Fever
Old Aug 28, 2007 | 02:49 PM
lacustoms's Avatar
lacustoms
Egt Fever
What is everybody running for egt's.
How much weight for the egt's?.
How long can you hold it there?
Where is the best to hold it?
What is your limit?
I am currently on a trip and i would like to know what i can do.
Old Aug 28, 2007 | 03:12 PM
nlemerise's Avatar
nlemerise
EGT is a function of a number of variables which makes it really difficult to say what they will be with any load/grade/speed/gear/tires/program/air temp/where you are measuring egt/etc.
What I can tell you is that you can easily run 1200 degrees for long periods of time...I am really conservative and run to a max of 1100 degrees...though I almost never see it towing anything, anywhere (I go over Hoover Dam pulling a 35' 5er and I travel the southwest in 100+). I have 4" exhaust, AIS filtration, DP-Tuner 40 hp tow pcm...it all depends on how your truck is set up.
maezo
Jan 24, 2015 07:22 PM
oldmerc
Sep 23, 2011 09:35 AM
sgrol
Sep 12, 2011 09:48 PM
gpsyking
General Diesel Discussion
20
Jan 31, 2010 05:59 PM
lumprsmith F150
May 7, 2006 02:03 PM
