no dash lights?!? please help!
Old Sep 2, 2008 | 09:46 PM
pidaster's Avatar
pidaster
Reviving an old thread here.
My dash lights stopped working tonight. Odd thing is, at one point when I flashed my high beams they came back on for a bit. Turn signals flash, high beam indicator does not work. All gauges read fine. Bad switch? Can't image the ground being bad with all else working.
Old Sep 2, 2008 | 10:49 PM
straightsix4x4's Avatar
straightsix4x4
fuse good? mine keeps taking fuses out, I'm going to have to tear into my dash sometime and look for the short, for now I just drive with no speedo in the dark, rest of my gauges are aftermarket and fuel gauge don't work anyway
Old Sep 2, 2008 | 10:55 PM
jcduerr's Avatar
jcduerr
Check your fuses , blown bulbs, grounds and shorts. in that order. a circuit tester (or oh im dumb tester, as i call it) is a big help
Old Sep 2, 2008 | 11:00 PM
pidaster's Avatar
pidaster
I put LED bulbs in it a few weeks ago. Also, I noticed when I changed to high or low beams the turn signal indicators will quickly flash during the change in beams.
Old Sep 2, 2008 | 11:39 PM
jcduerr's Avatar
jcduerr
try a volt meter and a partner and check for voltage spikes or drops
Old Sep 3, 2008 | 09:47 PM
pidaster's Avatar
pidaster
Well, I found the problem. The fuse was blown but there's more to it.
Yesterday I hooked my cb radio back up. I put the power wire on a switched source so I don't accidentally leave it on and run my battery down. Well, turns out the cb has gone bad. I brought it inside tonight and cracked it open to check it out. After I did a bit of work I carried it back outside and connected it. When I turned on the cb, the dash lights came on! I have no idea how this could happen but I'll just run a power wire to the battery and connect it with a relay. That and get a new cb radio.
Thanks for the help!
gcvt
Dec 11, 2014 07:24 AM
rottenstock
Apr 27, 2013 12:45 PM
widgetsmama
Jul 26, 2012 11:50 AM
1978fordf250
May 15, 2005 05:16 PM
