Need some insight here
Old Jul 24, 2012 | 03:53 PM
widgetsmama's Avatar
widgetsmama
Hi guys,
Got a question. My dash cluster is not working properly, by that I mean it doesn't light the gauges at all. All other lighting functions are working, but the gauges, no matter what I replace, including the headlight switch, lights and fuses refuse to light. On the upside, I have a new headlight switch, light bulbs and fuses! Lol! Anyway, being as this is such a dusty vehicle, having been a farm truck I am finding dirt in the most interesting places and I am wondering if the dirt that was on the back of the cluster could have messed up the circuit board that's attached to it and should I just give up and get a new cluster?
Thanks for the help!
Old Jul 24, 2012 | 06:11 PM
4x4 Bart's Avatar
4x4 Bart
I don't think dust on the back would be a problem unless it was damp. Look very carefully at the curcuit for a hairline crack. Unplug the ribbon connector and clean the contacts with a pencil eraser.
The white plastic is very easy to break. Handle it carefully
Old Jul 24, 2012 | 10:08 PM
VocaTexas's Avatar
VocaTexas
X2 on being VERY careful handling the cluster back. Some of them will turn to dust when you start messing with them.
I had a similar problem with lights on one of my Dents a few years ago. I pulled the cluster out and took a Q-tip and alcohol and cleaned the light socket contacts and the printed circuit around the light sockets. On mine that did the trick. There was apparently enough corrosion to keep them from making good contact, even though they looked fine.
Old Jul 24, 2012 | 10:24 PM
Nick Greer's Avatar
Nick Greer
I see corrosion on light socket contacts all the time in vintage guitar amps--especially ones that have lived near the ocean. On guitar amps, we use a light contact cleaner/electrical lubricant/deoxidizer called DeOxIt. On heavily corroded components like light sockets, input and output jacks, we spray it directly on the part, then use a small (.22 cal) copper bore brush (like you use in cleaning guns). If you do this--be VERY careful, use the bore brush, then go back over it with a q-tip, and it should get it clean. Sometimes the bore brush will leave tiny copper bits behind, so I suggest inspecting it very closely or buying a good bore brush, then actually brushing it out using a wire brush before using it.
Hope this makes sense--maybe it'll help!
Ng
Old Jul 24, 2012 | 10:38 PM
ChiefM's Avatar
ChiefM
There is a small metal box on the back of the cluster, that controls the voltage to the lights, this maybe bad.
Look at post 426: https://www.ford-trucks.com/forums/8...h-pics-29.html
Old Jul 24, 2012 | 10:53 PM
fmc400's Avatar
fmc400
MSEE
This is incorrect. The "metal box" on the back of the cluster is the instrument cluster voltage regulator and provides power to the gauges only. The dash lights are powered off the headlight switch rheostat. The two circuits are not related.
Old Jul 24, 2012 | 11:06 PM
widgetsmama
So thats what that blue thing is for! Good grief, I've been wracking my brain trying to figure out where the blue thing hanging free goes! Sheesh!
Anyway, the headlight switch has been replaced and I still have no instrument lights and as a matter of fact, when I open the doors, my overhead doesn't come on, either. It does, however, go on when I turn the **** all the way over, like its supposed to do. Doggone! I'm soooo not good with electrical!
Old Jul 24, 2012 | 11:08 PM
widgetsmama
I'm figuring that its safe to assume that the rheostat was replaced when I replaced the headlight switch or am I looking at something else?
I'm going to try to clean out the contacts tomorrow to see if that's whats hindering it. If it isn't, I'll be back on tomorrow evening! Lol!
Old Jul 24, 2012 | 11:12 PM
fmc400's Avatar
fmc400
MSEE
You are correct; the rheostat is internal to the headlight switch.
Old Jul 25, 2012 | 07:34 AM
ChiefM's Avatar
ChiefM
I need to NOT post when I have not had enough coffee.
Old Jul 26, 2012 | 10:28 AM
widgetsmama
Rechecked my headlight switch to make sure all of the connections are, well, connecting. Took all of the bulbs out and cleaned the contacts. Checked the pc board to make sure it is in place with no dirt in between it and the contacts on the back of the cluster. Checked to make sure all the wires are connected and in good condition. Nothing. Nada. The same lights that went on before still work, the instruments not at all. Go ahead, hit me with your best shots here.
Old Jul 26, 2012 | 10:42 AM
ChiefM's Avatar
ChiefM
Can you check voltage at the PC board with the cluster not mounted ?
Old Jul 26, 2012 | 11:50 AM
widgetsmama
Not quite sure how I would go about doing that. =o/
Frieghtlinerdriver
2004 - 2008 F150
Nov 8, 2013 07:30 AM
Spool&Go
15
Oct 10, 2012 04:42 AM
b4hntn
1978 - 1996 Big Bronco
Jun 17, 2012 04:34 PM
Fordman_95
Mar 31, 2011 10:08 PM
rgp
1983 - 2012 Ranger & B-Series
Nov 19, 2006 08:20 PM
