Another AIH question
Old Aug 28, 2007 | 11:42 AM
ztodd377's Avatar
ztodd377
Question Another AIH question
I know the AIH is something that is commonly deleted and I'm pretty sure it's only purpose is for extended idleing, but what exactly is it supposed to do for the truck on those extended idles? I live in Alaska and in the winter time, idle times can reach 20 minutes +.
Old Aug 28, 2007 | 12:07 PM
15 and 92 Dad's Avatar
15 and 92 Dad
If I lived in Alaska I would leave it, as you probably already know it preheats the incoming air at certine temperatures, some of the more exp guy's will chime in.
Rich
Old Aug 28, 2007 | 12:15 PM
Pocket's Avatar
Pocket
It's designed soley to reduce white smoke on cold starts in the winter. It's an emissions related item, and really doesn't do anything for warming up the engine.
Old Aug 28, 2007 | 12:33 PM
ztodd377's Avatar
ztodd377
Sounds good. It's comin out then. If the smoke gets too bad, then I can just put it back in for the winter I guess.
Old Aug 28, 2007 | 12:40 PM
CSIPSD's Avatar
CSIPSD
Oil temp has to be above 140, parking brake has to be on, and air temp has to be below a set point I cant recall... IE it never comes on...
Old Aug 28, 2007 | 01:23 PM
ztodd377's Avatar
ztodd377
Smile
That's good to know. I don't set my parking brake in the winter because of potential freezing problems so I guess my AIH would never come on anyway. Thanks.
Old Aug 28, 2007 | 02:56 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
So what is the purpose of actually removing/deleting this? What is the benefit? Thanks
Old Aug 28, 2007 | 03:00 PM
TNT in Round Rock's Avatar
TNT in Round Rock
it's pretty large and actually obstructs the air flow. You can simply plug it .. or you can can get a plug with a compression fitting to attach your boost gauge
Old Aug 28, 2007 | 03:03 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Has anyone actually felt any performance gains with this? I see the plug is about $8, just curious? Thanks
Old Aug 28, 2007 | 03:58 PM
indebt's Avatar
indebt
you can remove the plug and just hack off at the threads and save yourself the $16 to replace it! (if you do make sure you clean of the burrs!!!!!!!)
Old Aug 28, 2007 | 07:04 PM
clux's Avatar
clux
I certainly didn't, My opinion is that this is a "feel good" mod, doesn't really do anything unless you need the boost reference port.
This would be a great mod for gene to apply some physical modeling to calculate if it really does any good.
