radiator issues
Old Aug 27, 2007 | 09:59 PM
bctcattle's Avatar
bctcattle
Question radiator issues
just purchased a 1968 or 69 f250 4x4 with 4speed and 360. Can someone tell me which radiator this truck is most likely to have. It is leaking real bad and would rather just replace with a new one.
Old Aug 27, 2007 | 11:25 PM
Mil1ion's Avatar
Mil1ion
One of these ?
http://www.rockauto.com/catalog/x,ca...,parttype,2172
Old Aug 28, 2007 | 04:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ALL Ford radiators have ID numbers on them. The number is either on the top tank, or one of the side mount brackets. Three different radiators were offered for your truck: Standard Cooling; Extra Cooling, or Super Cooling.
Another way to find out which radiator you have is to ID the fan shroud, as it's radiator specific. Look at the upper left front corner of the shroud for a Ford ID number, similar to: C8TA-8146-S. Note: if the truck has the Super Cooling radiator, the radiator support is different.
Old Aug 28, 2007 | 06:19 PM
bctcattle's Avatar
bctcattle
thanks
Thanks for the information guys. Bought this truck to use around the farm, but now I,m thinking, I might put a little work in it and see what happens. There will surely be a lot more questions down the road.
Old Aug 28, 2007 | 09:43 PM
f2501967's Avatar
f2501967
you may want to call 1-800-radiators. kragen wanted $269. for my radiator. at radiators i only paid $219. but mine was extra cooling. mine has the 3 rows in it.and i got in 1-2 days, delivered at my front door.
Old Aug 29, 2007 | 07:19 AM
BobbyFord's Avatar
BobbyFord
Stay away from "Made in Indonesia" radiators.
Old Aug 29, 2007 | 09:21 PM
f2501967's Avatar
f2501967
mine was not made in Indonesia, it was the same exact radiator that i would have gotten from kragen. unless kragen get their radiators from Indonesia.
Old Aug 29, 2007 | 09:41 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Don't be surprised.
Get your radiator recored at a large local radiator shop, will cost more but what's your engine worth?
Check out the thread that supplies radiators then read the "more information"
about it may be plastic/aluminum.
At least you will not have a problem with a leak as water and rice go together,
"Got Rice?".
Old Aug 29, 2007 | 11:23 PM
BobbyFord's Avatar
BobbyFord
Originally Posted by Beemer Nut
Don't be surprised.
"Got Rice?".
I always go with a Modine re-core
