Rough Idle
When I do the TPS I will post up a how to.
if not, then please **** off and go back to the Toyota forums. we're not here to candy coat, but when you have 7 posts and 6 of them are of problems, well it's kinda hard to take ya seriously. people have issues, but very very few jump onto a website forum and "spread the love" when an issue exists and nothing else
btw, how is the tps recalibration going?
Anyway I'm glad you guys came back like that i would have been concerned if no one stood up for the truck...
TPS -I looked at http://www.fordfuelinjection.com/?p=30 and only found the voltages at the bottom. I assume you the steps are;
1) Get the truck to running temp
2) Check the voltage with throttle closed -if it needs adjusting keep going
3) Loosen TPS screws
4) Tap the TPS to change its position slightly
5) Rev the engine a little between taps
6) Let RPMs settle & take reading -if reading is off go back to step 4
Sound right?
That is why I love my 72 F-100. If it runs like a soup sandwich, it is my fault. I still enjoy my 04 STX, but man I wish I could just get ride of the rough Idle.
I rolled into the drive, opened the hood, saw or heard no blow-by at the coilpacks.
Turned it off, turned it on, drove around the block, nothing.
Now today, the same thing happened, exactly the same way. Initial steering vibration, followed by the motor clearly running roughly, getting worse, just before I pulled to a stop. Re-started again, drove around the block, nothing.
Can't wait till tomorrow to see if I make it home again.
This morning, same condition, vibration getting progressively worse, even as I slowed, but the motor seemed to be running fine, I was thinking maybe clutches in the limited slip???
Pulled into garage, and vuella, the rear discs were very hot to the touch, very, in fact, I could smell brake linings! I think my emergency brake cables are stuck!
I wouldn't have thought for a minute that this would not work after only 30K.
I guess I'll jack it up and have a look, pull a wheel, whatever. Has this happened to anyone else? Later, Bob
