Adjusted steering and now it wanders...
Old Aug 27, 2007 | 07:37 AM
MarkMoore's Avatar
MarkMoore
I never really experienced the wandering that most people complain about - maybe it's just my driving, but my X always 'felt' like I tought it should. I did notice some play in the steering, I could wiggle the steering wheel bak and forth about 2-3 inches of travel, w/o significant response, so I decided to tighten the steering box as many have suggested.
I only adjusted the allen bolt about 3/4 - 1 full turn (my markings did stay due to the sweat dripping off of me - I should know better than to do something like this when it's 101* outside).
Now when I drive down the road, I feel some wandering and it feels like I have to 'jerk' the steering to get the truck back on the road. the steering doesn't feel 'too tight', but after driving for a short while it feels as if it 'sticks' a bit. Anyhow, I plan on loosening it up a little tonight (time permitting) by backing it off 1/4 to 1/2 and we'll see what happens.
As anyone else experienced this after the steering box adjustment?
Old Aug 27, 2007 | 07:47 AM
SFeintuch's Avatar
SFeintuch
Sounds like you went too far, Back it up a little you should be fine.
Old Aug 27, 2007 | 02:19 PM
1 Excursion camper's Avatar
1 Excursion camper
Do you have a rear sway bar on your X?
Old Aug 27, 2007 | 05:00 PM
BAJI26's Avatar
BAJI26
I did mine and its sweet now... you just need a hair of a clockwise turn about a 1/4 or less.
Old Aug 27, 2007 | 09:20 PM
MarkMoore's Avatar
MarkMoore
Nope, no rear sway bar, but what I'm experienceing is not sway... but more like the X trying to go one way and me trying to pull the other, and it getting stuck just a bit.
I'm nearly 100% sure I over tightened the steering box. I didn't get to it today, but maybe tomorrow.
Old Mar 11, 2008 | 08:28 PM
jsduty's Avatar
jsduty
ieed to do the same but dont know how
Old Mar 11, 2008 | 09:59 PM
676869Ford's Avatar
676869Ford
Its easy to "over-adjust" a steering box. If you get the mesh a little too tight the vehicle will continue to move in the direction of the last steering input, and never really track straight. You end up constantly correcting left, then right, then left...
One turn is ALOT. I'd definetly back it up and tweak it a 1/4 turn at a time until its just right.
Old Mar 12, 2008 | 06:36 AM
MarkMoore's Avatar
MarkMoore
Speaking from experience - I totally agree.
I finly got mine close to where I want it - at least for now. With warmer weather moving in, I do a little more tweaking. Plus I plan on adding the RoadMaster Active Suspension, so I will probably have to tweak it again after that.
jsduty - just do a search for 'steering box adjustment', it been discussed a lot and there are several post describing it (with pictures I think).
Old Mar 12, 2008 | 04:41 PM
jsduty's Avatar
jsduty
thanks for the input cant wait to try and stop the play
Old Mar 12, 2008 | 08:00 PM
bnuvp's Avatar
bnuvp
Okay, now that sounds like what mine has been doing this winter, getting stuck or tight then fighting left then right. Here's the kicker, my truck has 118K+ and the steering box has never been adjusted. Answer me that. I thought it should be getting looser over time.
Old Mar 12, 2008 | 09:32 PM
VaSheriff's Avatar
VaSheriff
Mark, you big dummy!
As long as you have been around here I would think you knew
in advance the dangers of tightening the box too much!
Old Mar 13, 2008 | 11:17 AM
MarkMoore's Avatar
MarkMoore
Com'on, that was more than 6 months ago... I've learned a lot since then. Gimme a little credit.
Old May 13, 2008 | 12:34 PM
APEXDUCK's Avatar
APEXDUCK
Ok, I'm the new guy here. Pray tell what do I have to do to fix the wander issue. My 2005 X has this issue. I have a 99 250SD V10 with 112K that has always been solid. I just assumed the newer X had something different in the set up. Can someone provide a link with pictures of what I need to "tweek" sounds like a easy thing to fix, if you know where to look and make a 1/4 turn.
Thanks for the help.
APEXDUCK
Old May 13, 2008 | 12:57 PM
MarkMoore's Avatar
MarkMoore
On top of the steering box (follow the shft down the the front of the truck) you'll see an adjustment bolt. It has an Allen head screw and a nut. You have to loosen the nut, then turn the Allen head.
As noted above - it's easy to overtighten (speaking from experience), so turn about 1/4, then retighten the nut; test drive and continue to adjust as needed.
If you do a search for 'Wander', you'll find tons of info.
Good Luck and Welcome to the Club! Check out the 'Excursion Meet' thread at the top (it's a sticky) - you should come join us.
Old May 13, 2008 | 03:00 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
For a point of reference...here is a photo of what Mark is talking about...
Notice the 4 pink striped bolts...the one to adjust is in the CENTER. The allen wrench fits in the center and there is a jamb nut over that...
Firewall in this photo should be to your right and radiator to the left...
