Sponsored by: Auxito
Headers.....
Old Aug 26, 2007 | 09:26 PM
TheTinian's Avatar
TheTinian
Angry Headers.....
Well let me start off by saying that its 10:30 at night. I started this project at 9:30 this mornin. Bought a pair of Pace setter headers for my truck. Figured they cant be too bad to put on as i tore into the stock manifold. What a PITA. FIrst of all i broke 2 studs inside the block. Tried to drill em and use a easy out, and could not get them. So ended up staying there for now. Then the darn EGR valve would not line up for the life of me, and took me hours messing with the thing, doing a little custom bending, to finally get it on. Needless to say i was thinking this would be a complete waste of time and extreme aggrevation...until i drove it. And man, that truck will move now. I didnt think it would make that much of a difference. I guess it all equals out in the end... I wouldnt not recommend doin this tho unless you got a bunch of time and patience.
Last edited by LxMan1; Aug 27, 2007 at 10:37 PM. Reason: removed some unneeded cursing
Old Aug 26, 2007 | 09:29 PM
Dustin1690's Avatar
Dustin1690
Yeah they look like a pain in the butt to do it would be worth payin a shop the extra cash $$$$ to save from the headache
Old Aug 26, 2007 | 09:44 PM
lariat97's Avatar
lariat97
I put JBA headers on my F150. They were a PITA to install but I could really tell the difference with them. They really helped my midrange power. I soaked the studs with PB blaster the day before installed the headers. It took me 8 hrs but everything went right. I didn't break any bolts. I did have to bend the egr pipe a little. I took the fender liners out & could see all the bolts. The JBA headers lasted real good. I put over 70,000 hard miles on them without the first leak or problem.
Old Aug 26, 2007 | 10:35 PM
xtrford's Avatar
xtrford
Mine sucked huge b***s as well. I bought some cheap flowtechs, got them ceramic coated, and just recently I broke a wield at the collecter pipe. I throw the stock manifolds back on and I am never looking back.
Old Aug 27, 2007 | 03:38 PM
TheTinian's Avatar
TheTinian
Anybody else break the bolts in the block...if so did you leave em? or did you fix it. Im wondering if i should have fixed it or not.
Old Aug 28, 2007 | 07:43 AM
96sherm's Avatar
96sherm
best to fix them, its a good spot for a premature leak to start. so boys, are jba and pacesetter both decent ones to try?? i've been looking for them for my 4.6, but no one wants to comment in the exhaust section...
Old Aug 28, 2007 | 10:16 AM
xtrford's Avatar
xtrford
If I were to do all over again, and I do mean if, I would go with long tubes and get a custom Y-pipe to ensure a good fit. I have heard several times that most makes of shorties headers have a problem for fitting properly.
Old Sep 4, 2007 | 11:57 AM
sdeforest's Avatar
sdeforest
I installed some Hedmen Hedders on my 97 recently and they fit nice, the EGR tube bolted right up without bending.
Old Sep 4, 2007 | 12:27 PM
Silver Streak's Avatar
Silver Streak
I put the Kooks longtubes on mine 5 years ago and really like them. About a 4 hour install the first time, but no bolts broke off. I've a few sets since and have it down to about 2 hours if there are no problems.
