warm up valve?
Old Aug 30, 2007 | 10:53 PM
  #31
viperrtblck's Avatar
viperrtblck
sensor and tube are new...feel and see no leaks by manifold; CAN feel exhaust coming from top of tube with sensor removed; so all is hooked up correctly here. where do i start with this though? as far as diagnosing or workin on it. i watched today as it was "on and off on and off" and the little valve WAS moving by the turbine housing back and forth back and forth. hit brake or gas and still contines; LESSENS but continues. then i drive and dont notice anything (or truck noise overrides it) and is gone after i reach my destination; im almost just temped to unplug the damn solenoid at the turbo pedestal. could this hurt fuel milage though with this being in-operative?? i mean obviously warming up it would be altering; but as far as driving, making boost, etc. will fuel milage be hurt if it's just unplugged?
i guess what im tryin to get at here is does this affect or have anything to do wiht my wastegate operation if i unplug the solenoid?
Old Aug 31, 2007 | 03:36 AM
  #32
Kwikkordead's Avatar
Kwikkordead
With that sort of odd behaviour I would unplug it forever.
Unplug the solinoid and it will default open 100%.
It can later on be utilized as an exhaust brake or you can gut the innards if you so desire, but thats another thread.
For sure, disconnect that thing from computer control and leave it off forever with it acting like that.
It will in no way affect your wastegate performance.
Go ahead and unplug it and be done. The only time you really need it is in VERY cold weather.
Old Aug 31, 2007 | 07:36 AM
  #33
viperrtblck
thanks for your response...i'im glad it wont screw anything up adn is only used for warmup---ill unplug it this morning then and MAYBE plug it in once winters here to see if it does anything...but this is jsut so messed up..
thanks for everybodies help!
Old Aug 31, 2007 | 10:53 AM
  #34
k2vailkid's Avatar
k2vailkid
I agree 100%...
You can also buy a fooler to plug into the solenoid wire so that you don't get a SES light, I'm not certain that a code for the pedestal being unplugged will actually affect fueling, etc.... I put the fooler on my after swapping pedestals.
Old Aug 31, 2007 | 04:45 PM
  #35
viperrtblck
[QUOTE=k2vailkid]I agree 100%...
You can also buy a fooler to plug into the solenoid wire so that you don't get a SES light, I'm not certain that a code for the pedestal being unplugged will actually affect fueling, etc.... I put the fooler on my after swapping pedestals.[/QUOTE
how much for this fooler and where can i get it...i dotn wanna be drivin around with no light on!
Old Aug 31, 2007 | 05:08 PM
  #36
rbaker6336's Avatar
rbaker6336
[QUOTE=viperrtblck]
you won't get a ses light only a o475 code that doesn't seem to affect anything
Old Sep 3, 2007 | 12:19 PM
  #37
viperrtblck
would unplugging this sensor at the pedestal (i mean solenoid) totally defeat the purpose of me spending the 80 bucks and installing the new ebps tube and sensor in the front of the engine? or does computer controll read this sensor and make changes to things to help fuel milage? is this sensor and the warm up valve even in relation with each other?
Old Sep 3, 2007 | 12:42 PM
  #38
John311t's Avatar
John311t
No, the PCM uses the EBPS to determine change the fuel mapping and such, thats what ive read. My truck seems to run better with a new sensor and tube.
Old Sep 3, 2007 | 01:52 PM
  #39
rbaker6336's Avatar
rbaker6336
I have a EBPS fooler on mine got to where it would always throw a code with programer and still does sometimes withthe fooler
bebyb
Apr 7, 2014 07:18 PM
cak7700
Nov 15, 2011 08:33 AM
Swingshiftworker
Aug 29, 2009 08:53 PM
Jim McCarty
Dec 21, 2008 04:07 PM
Ekkehard
Modular V8 (4.6L, 5.4L)
Feb 2, 2008 03:25 PM
