Heads vs. Manifold
Old Aug 26, 2007 | 07:10 PM
just-n-time's Avatar
just-n-time
Angry Heads vs. Manifold
351W block 302 Heads I have had the same trouble before on a 351 with 302 heads, just want to check with the other members concerning water leeks.the heads are of C80E (1968) when I place the manifold gasket on them I have an area that dose not get coverd and must be pluged with silecone.Is it the year of the heads or am I using the wrong gaskets?
Old Aug 27, 2007 | 05:33 AM
HemiEater's Avatar
HemiEater
most gaskets have enough to cover the holes. They should have a cut out made into them so they work on either head. I use felpro..not sure on the number.
Old Aug 27, 2007 | 05:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford intake gasket sets
1962/76 221/260/289/302 2V: D1AZ-9433-B
1969/74 351W 2V: D1AZ-9433-C
Old Aug 27, 2007 | 08:38 AM
HemiEater's Avatar
HemiEater
late model heads...........
early heads
Just make sure the gasket covers the hole on the head and intake.......
Old Aug 27, 2007 | 08:04 PM
just-n-time
well I am useing the early 302 with 58cc chambers,the gasket covers all of the intake just fine and most of the head.But at the front (right head) and the exact place on the left head wich of course is at the back,the gasket is just larger than the matting service. I will look up the ford part #s thanks.JNT
Old Aug 28, 2007 | 03:53 AM
HemiEater's Avatar
HemiEater
just get a set of felpro intake gaskets....I have never had a problem they work for both heads.
Old Aug 28, 2007 | 09:05 PM
baddad457's Avatar
baddad457
If you're trying to use 302 heads on an early 351W, you must also swap intakes to a later (77-up) 351W The early Windsor intakes have 4 extra bolt holes in the coolant ports (1 per port) that will be open holes if you use a non early Windsor head under it.
Old Aug 30, 2007 | 03:58 PM
just-n-time
Edelbrock 2181 set up as non EGR unit.JNT
Old Aug 30, 2007 | 04:51 PM
fast83's Avatar
fast83
are you using the 302 heads for the compression or what? you would probably be better off getting some aftermarket heads that will flow better and have a choice on CC size, anyway just a thought!
Old Aug 30, 2007 | 05:08 PM
HemiEater's Avatar
HemiEater
I don't see the problem.....same gasket for the 302 and 351W
Old Sep 1, 2007 | 09:53 PM
just-n-time
Well this is engine #2 that I have done in my shop (351W) with 302 heads and felpro gaskets,that have given me trouble at the afore mentioned spots.If you do not put sealer in the corner of the gaskets you have a water leak. I do not under stand why its just me!
Old Sep 2, 2007 | 05:09 AM
HemiEater's Avatar
HemiEater
you need a camara...post some pics...
Old Sep 2, 2007 | 08:19 AM
HemiEater's Avatar
HemiEater
just remembered I had a set kicking around.
Felpro 1250
Old Sep 2, 2007 | 10:21 AM
HemiEater's Avatar
HemiEater
here is a 351W head i ported..only pic I could find......
I can see where the intake might leak if the bolt hole was not pluged or the early intake was not used like baddad457 said.....
Old Sep 2, 2007 | 11:18 AM
just-n-time
Hemieater, I do have digitale, but other than posting pics on my gallery, I have not gotten any in postings. The block was recieved with out heads, and as you say they are very close to the same,the recon heads are of a 302 also his work (a frend needing help) in lew of money that seams to be the way I get paid but I am retired so thats cool.
