F4TE or F4 E
Old Aug 26, 2007 | 06:56 PM
4x4Junky's Avatar
4x4Junky
F4TE or F4 E
Went to check the block on the engine I recently purchased and was expecting to find F4TE. It is a 94 engine out of a Lightning, so T and of course E for engine. The 3rd location is blank. Went back to doublecheck...and it is blank. I did a search and found nothing. Any reason this might be?
Thanks,
Anthony
Old Aug 27, 2007 | 12:34 AM
customfoam's Avatar
customfoam
I have the same thing on my block wonder why
Old Aug 27, 2007 | 01:33 AM
andym's Avatar
andym
Probably a casting error. A 94 truck has to have a F4TE block, so what else would explain it?
Old Aug 27, 2007 | 07:19 AM
4x4Junky's Avatar
4x4Junky
Not sure what else would explain it. Was wondering if any 351W blocks ever would have come with no third digit. Only thing I was considering was if the block had been changed at one point. Seems like most of it is original. Almost every part I can find has F4 part numbers on it.
If I heard correctly, this is supposed to be a roller block...just hoping someone didnt change it.
Anthony
Old Aug 27, 2007 | 08:14 AM
robprime's Avatar
robprime
An F4TE block I recently purchased had both the '4' and the 'T' missing, so I guess that this is not a rare occurrance. It may be from a run of blocks made at the same time in a particular plant, as the block I have is also a '94. Well, the truck was, anyway. A 09/94 build date for a '95 truck. Don't know which plant made the block. If Ford gets it's blocks like it does it's intake manifolds, etc, then it could be one of a number of block suppliers. Does make for a bit of uncertainty when trying figure out exactly what it is that you have.
Old Aug 27, 2007 | 09:26 AM
robprime's Avatar
robprime
Old Aug 28, 2007 | 06:46 AM
4x4Junky's Avatar
4x4Junky
Originally Posted by robprime
Yea, thats pretty much what I am dealing with. Odd that this happens. I picked up the engine used...and honestly a lot cheaper than I expected...so was half concerned that there could have been some games played. Went through and found as many part numbers on every piece I could find. Almost everything is a perfect match. The oldest was the timing cover, but that would hardly be reason to complain.
Anthony
Caveman2851
Jun 16, 2015 04:50 PM
Rusty_Old_F250
Large Truck
17
Dec 25, 2014 12:46 AM
460plowtruck
May 22, 2013 12:20 AM
NitrousAl
Aug 18, 2002 11:22 PM
