I bought my 99' 250 with approx 130K on it. From what I can tell, the trans has been removed and other alterations have been made prior to my ownership. The previous owner was a Captian in the AF and seemed to take really good care of it.
I work at a large dealer and have looked under the hoods of several 01-04 V10s and the ports on the intake manifold look exactly the same as mine. When I was building mustangs, the improved heads had a more retagonal port than non-pi heads.
My truck runs really well for a less-than desireable 99' V10. I was wondering if the engine or heads could have possibly been already replaced.
If you look up that the head from between the fender and the tire you should see the PI casting mark by the front exhaust port if it is a PI..I was looking on the pass. side of motor..
