Volt meter
Old Aug 26, 2007 | 10:03 AM
WayneH's Avatar
WayneH
Volt meter
New to the forums so pardon me if I couldn't find (after a search) the answer.
1996 F-250 Crew Cab 2-WD, 149,000 miles. From day one the volt meter would drop after starting, then move back up past center after a few moments. And stay there regardless of engine RPM. About a year ago it started staying below center. If the RPMs were increased it would go back up, but at idle it still drops. No problem starting, good batteries, no other problems. Is this a flaky meter or is there a hidden problem?
Thanks,
Wayne
Old Aug 26, 2007 | 10:08 AM
F0rdF0rever's Avatar
F0rdF0rever
Welcome to the forums Wayne. Your volt meter drops after starting because the glow plugs are sucking the power. The plugs turn off then your meter reads normal. As far as your low meter now, im not sure. Someone else will chime in for sure. Maybe a bad connection somewhere.
Old Aug 26, 2007 | 10:13 AM
WayneH's Avatar
WayneH
Yeah, I understand about the glow plugs and the alternator bringing the battery up to charge after a start. Hopefully someone will chime in.
Old Aug 26, 2007 | 10:17 AM
Neal 97 250's Avatar
Neal 97 250
I would take it to autozone or something similiar to have them check alternator. Maybe even take it off and take to them to isolate it from other hidden problems. How old are the batteries. Also use a test light to verify that the GP's are shutting off and not staying on.
BTW Welcome, and feel free to ask any question at anytime. We love it.
Old Aug 26, 2007 | 11:46 AM
c00nhunterjoe's Avatar
c00nhunterjoe
http://www.partsamerica.com/productd...ype=11&PTSet=A
get it tested but sounds like the alt is takin a dump, that link is best bang for buck, its paladine but when you open the box its all stamped ford motorcraft on the parts, including the regulator, 120 bucks, lifetime gurantee
Old Aug 26, 2007 | 12:06 PM
WayneH's Avatar
WayneH
Excellent, thanks for the link. I noted at the PDF for the alternator it mentions this:
Note the small regulator plug is a frequent cause of bad connections. This may prevent the alternator from charging properly.
I'll check that first.
Thanks.
