I have 78 with a 460 automatic it has a holley750 the disributer is been replaced a year ago with the plugs and wires . But one day i was driving and went to pass a car and when it comes on real good about 3500rpm it pops though the carb and will keep doing this untill you let off the gas. Ihave replace the power vale in the carb butt it wasnt bad.Any suggestions?
I bet the little hose that connects the distributor to the vacuum source on the carb (do not use manifold vacuum for the distributor) is cracked and leaking. While you are in there, its worth it to replace any suspicious hoses. Most parts stores have a variety of vacuum hose diameters available to choose from.
ok vacum secondarys ,i set the timing at 12degs \yes it is on the mat &the flots are fine & i checked the power valve it was fine, i replaced it anyway and total advance im not sure
