Modular V10 (6.8l)
10 plugs down
Old Aug 25, 2007 | 11:07 PM
XLnAK's Avatar
XLnAK
10 plugs down
I pulled my self without to much grief. What seemed to be a most daunting task turned out to be not so bad. before attemping this on my 04 I read alot, here and manuals OE and Haynes/chilton. I purchased a new 40-200" pound, 11inch Torque wrench. A set of 3/8ths exstentions 1,3,6,.
I found the new clicker inch pound wrench alot more user friendly than my old bar type thats about 15 1/2" or so long and several years old, and it never hurts to have more shiny exstentions around. I used alot of different combos of exstentions and was able to not take any thing apart other than the work at hand. Neat stuff.
The only real heads up I would add to things is just how important it is, to have an air exstention for forced air cleaning around the plugs before removal. I created mine from plastic and rubber hose to reach down deep into the pockets. Not a real field job with the kind of exstensive need I found with my rig. Dust, sand , small items came out of all 10 holes at 50 psi or so. The first hole I blasted with a hose end at close range from many angles and times and to my dismay the pocket still held to much dust, in about 10 degrees of the chamber bottom . I found a thread after doing the work that showed a less flexable yet just as well thought , copper tubing air attachment for his blower tool. Cop boots I didn't have on hand,but will in about 30,000. Does anyone have COP, boot or Transfer spring prt#rs . A couple of my boots have small cracks starting.
At 59,000 miles, My boots didnt want much to do with letting go of the plugs. The spairing use of dielectric grease at the origanal install seemed to be the culprit,and caused two boots to pull off COPs during removal. Although abit un nerving , both boots did go back on after cleaning.
Thanks for all the insight. Without the heads up Ive gotten here, I might have not changed the plugs till the far out, 100,000 recomended service. Yikes. .062 gap on several already.
Old Aug 26, 2007 | 07:00 AM
Fredvon4's Avatar
Fredvon4
Great post--- Good timely heads up----new guys are getting the BSEG V10 machine every day and coming here looking for exactly this type of information
Give this brother some reputation points guys! I did.
Old Aug 26, 2007 | 10:02 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Done!
Old Aug 26, 2007 | 04:23 PM
hydro_37's Avatar
hydro_37
An excellent post and the right time of year for it. Winter will be upon us way too soon and the maintenence for that time of year will need to be taken care of.
Old Aug 27, 2007 | 06:15 AM
Move over I'm coming's Avatar
Whats a reputation point? Sounds like something I need for my 2 daughters future suiters. The former will never have any points.
Just asking, Rich.
Old Aug 27, 2007 | 06:28 AM
Monsta's Avatar
Monsta
Sit. Stay.
Each post has a scale to the top right. Click on that if you like what someone has to say in that post or just in general. More reputation means more little green squares. More little green squares means a bigger bonus for me and the mods at the end of the year.
NOT!
Old Aug 27, 2007 | 06:51 AM
lswartz's Avatar
lswartz
NOT!
We need a little more help on this, I did & he still only has 1 little green square. Could you donate a little of that bonus for a 2d square?
It was a good post for all. I now clean out around any spark plug before pulling (including lawn mower).
Old Aug 27, 2007 | 12:17 PM
Monsta's Avatar
Monsta
Sit. Stay.
Ya know I don't know how many rep points you gotta have to get that second square. The rep point thing is kinda complicated. I'm not sure how the whole point system works. Some people who give rep points don't get them to "count" towards a person because they (the one giving the points) may not have enough posts. It's all very, overly complicated...
Old Aug 27, 2007 | 05:21 PM
XLnAK's Avatar
XLnAK
Thanks for the Rep points . With or without em This site has been, as I'm surer it will continue to be, an awsome representation of resorce. and great comrodery. Hats off to all. Don
Racerguy
1997 - 2003 F150
661
May 17, 2022 07:37 PM
68 351 bronc
Modular V10 (6.8l)
48
Sep 25, 2019 09:51 AM
JWA
Apr 16, 2019 08:27 PM
f250mtnbikr
Jul 9, 2016 10:27 PM
HaulStroker
Dec 28, 2015 05:57 AM
