Transmission troubles
Old Aug 25, 2007 | 08:36 PM
dyers_666_eve's Avatar
dyers_666_eve
Well to start things off i just want to say that im new to this site. So be gentle. My friend has a 76 ford pick-up and he is having trouble with the tranny. Its an automatic so im guessing a C6. we just got the truck runnin but whenever you first put it into gear there is about a 10 second delay before the tranny actually gets into first. This happens on start-up and after coming to a complete stop. Im stumped. Once it actually hooks up, its goes through the gears just fine. Any thoughts? Thanks in advance
Old Aug 25, 2007 | 10:19 PM
One79one71's Avatar
One79one71
leaking past a seal inside tranny. 10 sec is extremely long so I think its rebuild time. Has it sat for a long time? You could try the Ford tranny conditioner or Lucas tranny conditioner.
Old Aug 26, 2007 | 12:01 AM
sc00ter's Avatar
sc00ter
Just rebuilt mine for the same thing- seals on the foreward clutch will be rock hard. Be sure to check the clearance on this clutch pack when you reassemble- the snap ring that retains the return spring and the snap ringthat holds the top pressure plate can be reversed this will leave you with too much clearance in the pack.
Old Aug 26, 2007 | 12:23 PM
dyers_666_eve
It did sit for a couple of years before we got it running. Does anyone know where to order a good inexpensive rebuild kit?
Old Aug 27, 2007 | 04:51 PM
classicranger's Avatar
classicranger
I think this is a good deal. don't forget to get a new torque converter,
the old converter could contaminate the trans.
http://www.northernautoparts.com/Pro...ctModelId=9120
Old Aug 28, 2007 | 12:34 AM
dyers_666_eve
wow that doesnt look like a bad deal at all. Thanks for all the help. Looks like im gonna tackle this in about a week or so.
countryboy73703
6.4L Power Stroke Diesel
22
Nov 20, 2021 07:04 PM
gtstill
1983 - 2012 Ranger & B-Series
Jan 18, 2017 07:04 PM
Hoehandle
Jan 28, 2016 02:42 PM
BroncoBilt
1978 - 1996 Big Bronco
Dec 27, 2014 08:51 PM
madpogue
Jan 1, 2013 09:12 AM
