really confused
Old Aug 25, 2007 | 06:48 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
really confused
i removed my 10k mod and now my truck black smokes more way more then what it did before i just removed the 10k until i get a pyro but now unless on of u all think i had it hooked up wrong before i am going 2 leave it out it poors black smoke now when i shift and everything is there any way that i may have hooked it up wrong before???
Old Aug 25, 2007 | 09:43 PM
c00nhunterjoe's Avatar
c00nhunterjoe
probably hooked up wrong, not sure why you are smoking that much on a stock truck? put the resistor in line with the blu\red wire not in the back of the connector
Old Aug 25, 2007 | 10:47 PM
powerstrokeddiesel
thanx joe maybe my truck has had bigger injectors put in before it litterally rolls black smoke more now then what it did before since i took out the fuel pressure shim so u are saying my truck should black smoke more if the resistor is installed correctly???
Old Aug 25, 2007 | 10:49 PM
powerstrokeddiesel
and joe u r basically saying cut the blue with a red stripe wire and solder it in
Old Aug 25, 2007 | 10:58 PM
fuelman's Avatar
fuelman
Yes thats the way
Old Aug 25, 2007 | 11:01 PM
fuelman's Avatar
fuelman
Not sure why your taking out FPR shim, that should help lessen smoke due to a little better atomization check air filter is not dirty
Old Aug 25, 2007 | 11:06 PM
powerstrokeddiesel
so taking out the fuel pressure shim lessens black smoke???
Old Aug 26, 2007 | 08:50 AM
c00nhunterjoe
adding the shim and the 10k will give more fuel resulting in more smoke, click on my pic link in my signature and look at the icp mod link, yes its the blu\red
Old Aug 26, 2007 | 08:56 PM
powerstrokeddiesel
it does not smoke much more then what it did without the 10k mod nd fuel pressure shim now that i got it...
Old Aug 27, 2007 | 06:48 PM
ztodd377's Avatar
ztodd377
What exactly is this mod for?
Old Aug 27, 2007 | 07:02 PM
c00nhunterjoe
10,000 ohms in the path from the icp to the pcm makes the pcm think the oil pressure is low and raises it causing more fuel to go in the motor
wesley78
Jul 7, 2011 10:48 AM
Diablade
Sep 28, 2007 08:31 PM
shendoa
Jan 19, 2005 05:08 PM
