Sponsored by: Real Truck
2001 front dana 60 from dually f350
Old Aug 25, 2007 | 05:46 PM
robjs111's Avatar
robjs111
does anybody know if a 2001 f350 dually has a true dana 60 not the dana 50 or 55 that ford has been using on the 1999 and up superdutys?? also the dana 60's from dually's have a bigger or wider front hub assembly but can that be changed for a single real wheel f350 front width??? looking to swap dana 50 on my 2001 f350 to a true dana 60. thanks,
Old Aug 25, 2007 | 09:31 PM
SolidGround's Avatar
SolidGround
Let me know when you do this, as I'd be very interested in your front-end.
And yes, a F-350 DRW 4X4 front-end will be a Dana 60.
Old Aug 25, 2007 | 11:42 PM
robjs111's Avatar
robjs111
is it a true dana 60 or a dana 50 or 55??
Old Aug 26, 2007 | 12:54 AM
SolidGround
F-350 DRW 4X4, should be Dana 60, Dana 50's are/were used in 3/4 ton's and select one ton's (SRW) but only some, all DRW iirc, are Dana 60's.
-Jet
Old Aug 26, 2007 | 12:58 AM
robjs111's Avatar
robjs111
can the width of a dually dana 60 front end be narrowed to fit a single rear whell f350 2001?? want to get rid of dana 50 have right now? thanks.
Old Aug 26, 2007 | 09:32 AM
mech2161's Avatar
mech2161
Just unbolt the extensions and it is regular width.
Old Aug 26, 2007 | 10:25 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
and the advantage of going to Dana 60s would be.....??
Old Aug 26, 2007 | 10:52 AM
rebelchevy02's Avatar
rebelchevy02
Larger ring and pinion, the axle shafts do not neck down to dana 44 size were it enters the carrier, it stays the size of the rest of the shaft, which means more splines. I dont rememember the exact measurements right now.
Old Aug 26, 2007 | 10:55 AM
robjs111's Avatar
robjs111
true dana 60 can handle bigger tires, more weight, etc. have 2 ring bearing on each side. built stronger and can last way longer.
Old Aug 26, 2007 | 10:56 AM
robjs111's Avatar
robjs111
if i unbolt extensions do i have to change out axle shafts to shorter ones?? thanks.
Old Aug 26, 2007 | 11:09 AM
rebelchevy02
Hold up a second haha. Superduty 60s, have a larger ring and pinion, and the axle shafts dont neck down were they go into the carrier. knuckles out are the same. The only way you can say it can handle bigger tires is in the carrier. They dont do any better at holding up in the wheel bearing department. The housings are near identical, which makes them hard to tell the difference. Im not sure were your getting two ring bearings on each side, they still have the sealed unit bearings. Now a dana 60 out of a 78, 79 f350 had kingpins, serviceable bearings at the hubs.
Edit: found the skinny on the 50 vs 60 info i found a while ago
Dana 50, with 30 spline shafts at the carrier. IIRC you have a 8.5 inch ring gear, 26 spline, 1.376" pinion, and 30 spline 1.31" axle shafts (were it necks down into the carrier) VS a dana 60, which started around 2002 in the front of super duties, which has a 9.75" ring gear and i think 35 spline 1.5" shafts, the whole length, and a 1.625" pinion shaft
Old Aug 26, 2007 | 11:21 AM
rebelchevy02
Im pretty certain you dont have to change the shafts, but youll have to swap out the wheel studs
Old Aug 26, 2007 | 12:56 PM
mech2161's Avatar
mech2161
[QUOTE=rebelchevy02]Hold up a second haha. Superduty 60s, have a larger ring and pinion, and the axle shafts dont neck down were they go into the carrier. knuckles out are the same. The only way you can say it can handle bigger tires is in the carrier. They dont do any better at holding up in the wheel bearing department. The housings are near identical, which makes them hard to tell the difference. Im not sure were your getting two ring bearings on each side, they still have the sealed unit bearings. Now a dana 60 out of a 78, 79 f350 had kingpins, serviceable bearings at the hubs.
This is correct!
There is a difference in the housing if you know where to look.
p0opstlnksal0t
Sep 12, 2014 02:50 PM
robjs111
Nov 12, 2013 07:14 AM
69crewcab
31
Dec 20, 2010 03:13 PM
dvw70
Feb 26, 2009 09:38 PM
Oval_obsessed
Nov 15, 2003 03:53 PM
