Question for you engine guys
Old Aug 25, 2007 | 04:46 PM
rustyc106's Avatar
rustyc106
5.4 engine is smokeing something awful. sometimes up to 2 1/2 quarts a day. There are no leaks it just burns it. Also the oil sometimes smells like gas. The boss man won't replace it till it bows. Any suggestions on what to do? Tried using Lucas but it doesn't even work anymore.
Old Aug 25, 2007 | 08:03 PM
ArgoExpedition's Avatar
ArgoExpedition
only way to tell for sure is to do all the tests. Compression and leakdown tests will tell you where the problem is.
General compression test: tell how well the rings are seating and what cylinders are low, if any.
Compression test w/adding oil to see if the compression rises will tell if its a lower end problem; ie ring failure (which I would suspect, that is a lot of oil)
Leakdown test can tell if there are some problems with the heads.
2 1/2 quarts a day is a lot and to me that qualifies as a blown engine; something seriously is wrong and depending on what could make it into a catastrophic failue.
Just my .02
Steve
Old Aug 26, 2007 | 04:10 PM
Fat Man's Avatar
Fat Man
Talking
Originally Posted by rustyc106
The boss man won't replace it till it blows.
I'd say that you should stop putting oil in it and drive it like you stole it until she blows!! That could be a good time! Of course this is the opposite of helpping you fix the issue...
Old Aug 29, 2007 | 09:57 AM
farky's Avatar
farky
f150
hey my 2001 f150 is doeing the same thing smokes like a train at start up.useing alot of oil.ford dealer of no help so iam trying to find someone to do compression test.
Old Aug 29, 2007 | 03:53 PM
gacyota's Avatar
gacyota
I'm with fatman - if the boss won't replace it until it blows - blow it up
Old Aug 31, 2007 | 01:07 PM
Frat-man-du's Avatar
Frat-man-du
Blow it baby! Not much you can do.
Back in the day we put a little fine sawdust in the oil - helped keep the cops from pulling us over - till we could get to the shop and drop the motor. Not sure if it was the sawdust or just stupid luck - I bet on the stuipd luck. Never do this with a modern engine with the tight tolerences today.
Old Aug 31, 2007 | 01:40 PM
Fat Man's Avatar
Fat Man
I heard my pops say they used to put sawdust in the oil to keep it from knocking while they were trying to sell a car. He also said never to do that to a car you liked! I guess in this case, since the truck is smokin' like teenager in the bathroom, it might be interesting to see what would happen...
Crazy - I know...
Old Aug 31, 2007 | 01:43 PM
Frat-man-du
Ha, true dat...nuthin to lose at this point.
Old Aug 31, 2007 | 01:45 PM
berry1234's Avatar
berry1234
Stop polluting my earth man. Don't add more oil, let the engine seize. Then add oil when it stops so they won't think you ruined it on purpose.
Frat-man-du
Good point!
