Torque shift transmission?
Old Aug 25, 2007 | 01:10 PM
ssturbodiesel's Avatar
ssturbodiesel
After 10 mins of normal driving conditions, the trans. temp gauge peaks and check gauge comes on. Fluid and filter have been recently changed. Any suggestions on what is causing the problem?
Old Aug 25, 2007 | 02:30 PM
LvTitan's Avatar
LvTitan
sensor itself could be bad, i've seen a few threads like that.
Old Aug 25, 2007 | 02:36 PM
04Xcursion's Avatar
04Xcursion
There is the possiblity of a bad sensor, but just to be sure confirm the heat. Pull over somewhere safe, crawl underneath and put you hand on the tranny pan. The overheat on the gauge is HOT, I think something like 250+, so you'll know if the trans is actually hot... If it is take to a shop, you've got problems.
Old Aug 26, 2007 | 02:35 PM
gvandyke's Avatar
gvandyke
I had the Trans Temp Sensor go bad. The guage peg to the top and then the trans strted to shift eraticly. Dealer said the sensor became contaminated. It is deep in the transmission. They updated my trans while they had it apart. Luckily it was still under warrenty.
__________________________________________________ _______________
2003 Ford F350 6.0 PSD C/C S/B 4x4 Lariat FX4
120,000 Miles
Warn Manual Locking Hubs,ARE MPulse Cap
BFG All-Terrain AT 285/75R16
Stock Air Intake, 4" MBRP Turbo Back (No CAT) "JET SOUND"
SCT XCal2 and Tunes from Matt @ Spartan
Old Sep 8, 2007 | 11:29 AM
ssturbodiesel
Thanks for the quick reply. It was the temp sensor. Now i'm up and running and enjoying my truck. Thanks again
waystro
Apr 1, 2013 08:55 AM
bixter1
Nov 11, 2006 03:20 PM
Miro
May 24, 2002 12:39 AM
rangrlvr
1983 - 2012 Ranger & B-Series
Feb 25, 2002 08:51 PM
bearclaw
Jul 8, 2000 02:47 PM
