Computer Chips & Tuners
OEM Chip for 5.0
Old Aug 24, 2007 | 10:53 PM
ss150's Avatar
ss150
OEM Chip for 5.0
I have a '92 F-150 5.0 (E40D) that runs really rough. It's been in the family for a long time. Several years ago, my uncle put a JET performance chip in it. My dad swears that it has run bad ever since, so I am trying to find a replacement stock chip. Anyone have one or know where I can get one? I am not looking for performance from this truck, I just want smooth reliability. Thanks.
Old Aug 25, 2007 | 09:29 AM
FTE Ken's Avatar
FTE Ken
There is no OEM chip. You simply pull out the JET chip from the service port and the PCM reverts back to the OEM tune held in the PCM.
Old Aug 25, 2007 | 04:24 PM
ss150's Avatar
ss150
That's what I thought, but my uncle said he left the stock one laying around somewhere, lol. He probably just forgot. I'll take a look here in a second. I'll pull the JET out.
Old Aug 25, 2007 | 07:56 PM
FTE Ken's Avatar
FTE Ken
Make sure you disconnect the battery first. Its possible to fry the PCM if you don't. The chip will sticking on the outside of the PCM box. Open the hood. On the driver's side firewall the PCM will be sticking through. It has a wiring harness bolted to it with a 10mm bolt. Now that you've located it, open the driver's door and look up on the firewall under the dash and you should see the PCM sticking through. Its a silver box (some aftermarket replacements are painted black). The chip will be a rectangular module sticking to the side of the box. For a Jet it should be black, possibly with yellow lettering. Pull the chip off and you're good to go. Sometimes clearance issues will require that you take the entire PCM out in order to pull the chip.
Hope this helps.
95F-150EddieBauer
Aug 13, 2013 01:13 PM
1992FordF150Custom
17
Nov 25, 2012 12:47 AM
640 CI Aluminum FORD
Apr 23, 2011 04:55 AM
ricalbuq
Dec 19, 2006 04:58 PM
KC99150
31
Sep 18, 2003 07:43 AM
