DP tuner switch mount
The solution was to remote the LED display chip to a different location.
I use a SPA digital dual gauge on a single A pillar mount, and there is enough room for the SPA programming button and the LED display chip.<O
Removing the LED chip from the DP switch is a daunting task, but obviously possible.
<O
The sunshades I made from aluminum <O
It all works just fine, I can feel and press the DP switch buttons and see the results on the A pillar display
The result can be seen at
http://usera.imagecave.com/Ferraridriver/Excursion/P1010011.JPG
http://usera.imagecave.com/Ferraridriver/Excursion/P1010012.JPG
http://usera.imagecave.com/Ferraridriver/Excursion/P1010015.JPG
