Strange oil usage
Old Aug 30, 2007 | 08:18 PM
Talyn's Avatar
Talyn
Nope. Thats not the mystery quart.
as for the filter, it holds less then a qt also.
I drained everything, filter and all into a pan, and filled qt bottles.
I got 4 and 3/4's
I even turned the engine over with the coil unpluged to get the oil setting in there out.
Old Aug 30, 2007 | 08:48 PM
justin25taylor's Avatar
justin25taylor
Thanks for the help gang. I will check the plugs, PCV valve, and compression and check back in.
Best,
Justin
Old Aug 31, 2007 | 11:02 PM
91 F-150 Farm Truck's Avatar
91 F-150 Farm Truck
Its the oil elf...
Maybe goes out the tailpipe in small amounts.
Old Sep 1, 2007 | 12:41 PM
Talyn's Avatar
Talyn
I've checked the tail pipe.
But when i loose any qt's
Its instant after a trip.
The seafoam in there though, i havn't went down a qt yet.
Old Sep 1, 2007 | 05:41 PM
justin25taylor
I still have not gotten home to check the plugs, compression, etc.
I did notice soot on the rear bumper. I looks like diesel smoke residue like m old 7.3 IDI used to leave.
I never see it smoke but I think I read somewhere that at high rpm the converter will "burn" up the smoke.
Is this true?
If so can we determine if I am running too many rpm's at 70-75 mph?
I have a 4.10 rear end and a C-6 trans. The truck is a XL model so it does not have a tachometer.
What is the "safe" cruising rpm for my 5.8?
The truck has 152,000 miles and was serviced every 3k like a clock.
I hope it doesn't need an engine but if it does I need to go ahead and do it. I really like the truck. With the utility bed it makes a great work truck for my needs. Other than the oil usage the truck is dead mint. You would have to see it to believe it.
thanks again gang.
Best,
Justin
Old Sep 1, 2007 | 10:49 PM
Talyn's Avatar
Talyn
YOu might just need a re ring and a head job.
Even if serviced well, if poor oil was used, it could have caused a few issues like stuck rings.
I only metion a headjob, because they are great! (for your truck!)
70-75 with 4.10s on a C6 would probably give you some High RPM's. But it shouldn't matter a whole lot.
Start cruzin at 60-65 see if there is any differance.
And install an aftermarket tach. They are fairly easy to install.
The guage wont be totaly accurate, but close enough to help.
Old Sep 3, 2007 | 03:40 PM
justin25taylor
Sounds good gang. I have slowed down to 60ish and will be sure to report back.
Thanks again,
Justin
Dan V
Apr 29, 2014 08:10 AM
IceBerg04
Mar 27, 2014 01:45 PM
Gage2502
Jun 10, 2008 11:36 PM
