air pump?
Old Aug 23, 2007 | 05:13 PM
cranky712's Avatar
cranky712
Question air pump?
ok i have it but dont know the purpose of it. its the air pump that is on my 85 f250 with a 351w. do i really need it or is another of the useless gas sucking devices that the epa wanted on engines?
Old Aug 23, 2007 | 05:51 PM
RickDill1's Avatar
RickDill1
Do not know what county you live in Washington. You may need it to pass inspection in your state.
Old Aug 23, 2007 | 05:54 PM
Franklin2's Avatar
Franklin2
It blows air into the exhaust to help emissions when the engine is cold.
Old Aug 23, 2007 | 06:30 PM
cranky712's Avatar
cranky712
whadda ya know
no evil empire emissions needed. and dave if its only for when the engine is cold could that be a factor that the engine dies after i start it up? i can restart it and it runs fine an it doesn't matter if i let it warm up or try to take off right away. i guess the real question is? can i take that messy snake nest out without much trouble?
Old Aug 24, 2007 | 12:22 AM
eco's Avatar
eco
The only prolem with getting rid of the air pump is that the cat converters wont last as long. If you have no cats, then there is no problem at all with removing the air pump.
Old Aug 24, 2007 | 10:36 AM
cranky712's Avatar
cranky712
did some research and the air pump is outta there. the amount of emissions from a cold to operating temp engine is minimal to the hassle of a system that was created to shut the epa up. its a system that actually uses more fuel to help reduce so called less emissions.
