trans swap
Old Aug 23, 2007 | 02:25 PM
THOR25's Avatar
THOR25
trans swap
hello, i have a 88 with a 302 and a automatic overdrive trans. will this trans. bolt up to my 89 300 cid.? thanks larry
Old Aug 23, 2007 | 11:19 PM
85e150's Avatar
85e150
AOD or AODE? Will bolt up, might not work as as electronics are involved and shift points might not be right. That can be fixed, though.
Old Aug 24, 2007 | 03:25 PM
rclarke's Avatar
rclarke
An 88 should have an AOD. It will bolt up to a 300cid 6 cyl just fine. You will have to find and install the proper linkage for the throttle pressure lever/valve.
