Stock Tires
Shouldnt the tire store recalibrate my speedometer? I was thinking P255/65R-17.
This is the tire:
http://www.discounttire.com/dtcs/fin...d=011892&ar=65
This is the tire:
This is the tire:
http://www.discounttire.com/dtcs/findTireDetail.do?rc=TXKINT&yr=2004&cf=false&c=2&s w=false&pc=31716&tc=GDYRH7&rf=true&rcz=76540&cs=25 5&dVeh=dVeh&rd=17&vid=011892&ar=65
This is the tire:
If you did not buy your truck new and want to find out which tire size was installed from the factory, look at the spare because I would care to guess that it is original. Here is a tire calculator to play with different sizes http://www.gordon-glasgow.org/tirecalc.html . I have heard the Goodyear Wrangler Silent Armor tires you posted a link to are very good.
The sticker inside the door read
235/17 for the tire and
17 X 7 for rim i believe.
Im looking for any tires that would fit on my rims right now but would fill in the large gap between the tire and the body plus tires that a wider then the ones I have one now, Id love to but cant afford FX4 rims at the moment.
I figured but I might be wrong that 255/65 17 is the biggest I can go. Is this correct? Again, thanks for the help.
I had 255 70 17's stock and changed to these in 275 70 17's.
Originally Posted by last5oh_302
I went with Firestone Destination AT's. No complaints, in fact I'm very happy with them. They balanced up nicely, they look great, and ZERO road noise, unlike the OEM crap that came on the truck. I replaced them soon after buying the truck. Destination AT's are rated right up there if you check the reviews as far as AT tires go:
The 255/65/17 is actually shorter (smaller diameter) than the 235/75/17. These specs. came from http://www.gordon-glasgow.org/tirecalc.html
255/65/17
Diameter: 30.05"
Width: 10.04"
Rev/Mile: 671
_____________________
235/75/17
Diameter: 30.88"
Width: 9.25"
Rev/Mile: 653
265/70/17
Diameter: 31.61"
Width: 10.43"
Rev/Mile: 638
275/70/17
Diameter: 32.16"
Width: 10.83"
Rev/Mile: 627
Going (up in height) to a 265/70/17 is actually less of a change in height than going (down in height) to a 255/65/17 (+ .73" for the 265, - .83" for the 255).
The 265/70/17 will only change your speedometer reading by about 1 1/2 mph @ 70mph. BTW if you go with a tire that you feel will warrant a recalibration of your speedo, your dealer can do it for you. I was quoted a price of $40 when I asked.
255/65/17
Diameter: 30.05"
Width: 10.04"
Rev/Mile: 671
235/75/17
Diameter: 30.88"
Width: 9.25"
Rev/Mile: 653
265/70/17
Diameter: 31.61"
Width: 10.43"
Rev/Mile: 638
275/70/17
Diameter: 32.16"
Width: 10.83"
Rev/Mile: 627
lastoh, those look great, did you have to recalibrate your speedo? is your truck a 4x4? (i know its on your sig but i remember someone with a black truck on here buying a 4x4 sticker)
Is it possible for me to use any of these tire sizes you mentioned:
255/65/17
235/75/17
265/70/17
275/70/17 with my current 235/70/17(stock I now believe) tires? Will they fit on my rim? Also my truck is a 4x2. When I plug my numbers in an online calculator on what I can put on my rim its either: P255/70R-17 or P255/65R17. The first size makes sense but this second one quoted is my "optimal" size but its height is shorter
The tire store recommended these:
Yokohama Geolandar A/T-S:
http://www.discounttire.com/dtcs/findTireDetail.do?rc=TXKINT&yr=2004&cf=false&c=1&s w=false&pc=43811&tc=YOKRA4&rf=true&rcz=76540&cs=25 5&dVeh=dVeh&rd=17&vid=008443&ar=70
FS, so any change in the tire side warrants a recalibration? Im glad to see that its not expensive
255/65/17
235/75/17
265/70/17
