Battery Discharge
Old Aug 22, 2007 | 04:22 PM
DixieDirt's Avatar
DixieDirt
Battery Discharge
Hi all. If I let my truck sit overnight, by morning the batteries will be discharged enough for it not to start. I was just wondering what fuses in both the engine compartment and the cab, should be hot with the key in the off position cause I have a bunch of em on well after I turn the key off and remove it. Or what would cause such a big discharge in such a short amount of time? I know I need new battery cables, could that be the problem?
Old Aug 22, 2007 | 04:37 PM
Neal 97 250's Avatar
Neal 97 250
That could be. How old are the batteries?
Old Aug 22, 2007 | 04:43 PM
DixieDirt's Avatar
DixieDirt
About a month old, they are the walmart everstart 1000 amp deals
Old Aug 22, 2007 | 04:58 PM
Action4478's Avatar
Action4478
You could have the alternator tested, or unhook it after you park the truck for the day & see what happens in the AM....
Old Aug 22, 2007 | 05:07 PM
Neal 97 250
I agree unhook the alternator overnight and see if it cranks in the morning. They will drain the batt if bad.
Old Aug 22, 2007 | 06:07 PM
Cuda_jim's Avatar
Cuda_jim
I think Rick nailed this one too, you guys in Mich are pretty smart
Old Aug 22, 2007 | 07:41 PM
Action4478's Avatar
Action4478
I appreaciate the compliment....I just got here before you did
Old Aug 22, 2007 | 09:49 PM
Neal 97 250
Keep us posted did any of this help?
Old Aug 23, 2007 | 10:23 AM
DixieDirt's Avatar
DixieDirt
I have unhooked the alternator and the batteries have a full charge so lets see where we are in a couple of hours.
Old Aug 23, 2007 | 12:14 PM
fuelman's Avatar
fuelman
If previous test doesn't work try removing both positive terminals tie one out of way so not to touch anything ,take other terminal and put a voltmeteror test light between battery post & terminal if you get more than 3-4 volts or light is on you have a drain. Make sure everthing is off while doing this.If you find voltage or light start pulling fuses 1by1.When light goes out u have found the circuit that is causing you're drain,Good Luck..
Old Aug 23, 2007 | 12:31 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
I was just going to say that, also works to take the test light and substatute a fuse if you have a dead short that keeps blowing fuses
Old Aug 23, 2007 | 04:08 PM
DixieDirt's Avatar
DixieDirt
Well, form 10 am till now the batteries have gone from a little better than 12 volts down to about 9.8, so I guess Its time to start pulling fuses. Sidenote, I pulled both positive battery cables and placed a volt meter between the passenger side positive battery post and the passenger side positive cable and got a reading of almost the entire total battery voltage. Am I doing this right?
Old Aug 23, 2007 | 07:11 PM
Cuda_jim's Avatar
Cuda_jim
Yep, that's right. You have a short somewhere. Hook a test light the same way start pulling fuses until the test light goes out, that will be the circuit you need to dive into.
Old Aug 23, 2007 | 07:17 PM
fuelman's Avatar
fuelman
YES pull fuses 1by1 then replace. Again make sure every thing is off.Start with fuses for dome lights & door locks first, they have power 100% of time.
Old Aug 23, 2007 | 07:22 PM
fuelman's Avatar
fuelman
If you have added any mods of any kind check those areas.Check anywhere around exhaust manifolds or pipes .
