Sorry about the delay in info all, but they have me working overtime again and haven't had much time to mess with the old ford. Anyways, I tried to pull fuses to see which one would make the light go out and that really didn't work. On the other hand, I have determined that there is power going through fuse positions, 4,5,8,9,12,13, and 16 in the cab and positions 1,2,3,4,8,9,10,13,15,17,18,19,20 and 21 in the PDB. I don't think all those fuses should have power when the truck is off with the key in my pocket. So where should I do now?
Disconnect all wires on the battery side of the starter relay,then reattach only the wire to the batt.redo drain test.This will test only startlng circuit ,use test light or meter. If you have power replace relay .
Well, it seems that I have found the draw or at least what fuses are allowing the draw. Fuse position 3 (in the power distribution box) will almost stop the test light from glowing and fuse position 13 shuts it off completely. Without fuse 3 removed, the test light glows amost as brite as if it were connected directly to the positive and negitive side of a good 12 volt battery. Now what exactly do the fuses provide protection for?
