MAF conversion, computer swap question.
Old Aug 22, 2007 | 01:05 PM
RC Dan's Avatar
RC Dan
I have a '95 F150, 5.0, manual. It has speed density. I looked around and I have more than enough parts to do a MAF conversion. I've got a good meter, engine harness, and all the other little parts you need. My question is on the computer.
Can I use an A9P computer with a M5OD 5-speed manual trans? I figure I need to swap around a few wires in the connector, so if anyone has info on this, it would be appreciated.
Old Aug 22, 2007 | 01:18 PM
Kemicalburns's Avatar
Kemicalburns
yes you can use that ecu. why are you changing though?
Old Aug 22, 2007 | 01:38 PM
RC Dan's Avatar
RC Dan
Will I need to swap any pins around on the connector?
I wanted to change it because I feel this engine, which came out of my '94, ran much stronger when it had MAF. The engine is a crate rebuilt. Has an aftermarket roller cam, which I believe is something similar to a mild RV cam. Bored .30 over with flat tops, it hits 195psi on a compression test when hot. Plus, I like to play around a lot and I've heard the Mustang computers have a slightly more aggressive fuel and spark curve. And, I may be able to bump my mileage up a hair.
Later, I'm changing the intake and I have some full-length headers to install. I'll also do some porting to the heads and lower intake. Now I've heard SD is a little sensitive to changes.
Old Aug 22, 2007 | 03:32 PM
Mr. M's Avatar
Mr. M
If you plan on modifying the 5.0 as advertised, I suggest you upgrade to the MAF setup. Otherwise, you will be looking at some pricey overhead costs to get the SD fuel maps to run correctly. The upgrade potential is almost endless with a MAF unit and an aftermarket FPR. The MAF ecu will relearn your new go-fast parts quickly. I'd suggest letting it idle for a good ten minutes prior to testing it out. I find that anytime I pull the negative off the battery terminal, it takes a bit for the ECU to learn how to properly idle on a 0.533" lift cam and other goodies. It's kinda neat watching and listening to the whole process!
The MAF ecu from the mustang will work fine with your M5OD. Now if it was an E4OD, you would be looking at some serious incompatibility. I assume your crate motor has the 1-3-7 firing order? If not, you might have to swap some injector wires...
Good Luck!
Mike
Old Aug 22, 2007 | 03:38 PM
BEWOLD's Avatar
BEWOLD
SD is very sensitive to change. SD I believe is also batch fire(bank to bank) and the mass air is sequential. Not sure on interchange of computers, A9Ps are supposed to be for autos, A9L is for standard trans. This might help http://brembs.net/cars/maf_conversion ( Hope I got that right )
Old Aug 22, 2007 | 03:51 PM
lostin90s's Avatar
lostin90s
If you get the 302 maf ecu you canget a tweecer to trick it to think the auto is there. Since you have the harneses ETc . Most maf truck moved the air sensor to air filter box so you will need it or to run extra wire to the intake one. Good luck have fun it really dose liven up things.
Old Aug 22, 2007 | 05:11 PM
RC Dan's Avatar
RC Dan
Mr. M, yes, it has the 1-3-7 firing order. Whenever I reset a computer, I always let it idle for a few minutes. Then I take it out, cruise around lightly till its warmed up all the way, and lay into it hard a few times. I've always got the smoothest running and idling engine this way.
The batch fire to sequential is where I may pick up a couple more MPG. Great link, btw. That site has links to even more info, too.
I'm thinking all I'll get is a few trouble codes when it looks for feedback from the tranny.
Old Aug 22, 2007 | 05:42 PM
EPNCSU2006's Avatar
EPNCSU2006
The A9P doesn't look for the transmission, so there won't be any transmission related trouble codes.
Old Aug 22, 2007 | 06:20 PM
lostin90s's Avatar
lostin90s
Hey guys I thoughtI canceled this post . I was going to rewrite and had to answer phone kid must have sent it.
Old Aug 22, 2007 | 06:25 PM
lostin90s's Avatar
lostin90s
I put the whole maf set up for 95 F150 in mine . I went from 13MPG to 15-16 MPG and the response is alot better. After I do the fordracing wires and msd coil and cap . It should really liven up. But good luck
Old Aug 22, 2007 | 10:24 PM
Mr. M's Avatar
Mr. M
You can bump the spark plug gap to 0.055" and beyond with that setup as well. I gapped my NGK's as 0.060" with the MSD coil and 6a box. Not a misfire in sight... all the way to 5500 rpm.
Mike
Old Aug 24, 2007 | 10:41 AM
RC Dan's Avatar
RC Dan
More Questions
Ok, I do not have the rest of the truck harness from the firewall to the main connector under the hood. I know the MAF wires and plug came from this harness, so I looked up and found that the "RTN Signal" goes to pin 9, and the other goes to pin 50. Then there is the power and ground. Is that correct? Cause I also heard about pin 36, 40 or 80, and 88. Also, are the extra wires needed for the injectors there from the main ECU connector to the under-hood connector? Or, should I just go to the junkyard and grab this section of the harness?
Thats alot of stuff that most MAF conversion write-ups don't cover. I must have went through like 15 of them and found this looking through wiring diagrams I already have. How come no one here has gotten around to putting a write-up on this site?
