Does it matter if the engine bay is cooled after a drive if you open the hood or not? I always open up the hoods of my cars once I get home to cool them down. My neighbors think I'm crazy as does my wife and kids..Does it have any benefits? IE..longer lasting hoses less heat dmg etc??
Good Question, kind of akward but I am almost positive it really doesn't matter unless you are having Heating problems. Nonetheless, I would like to know what people have to say.
So you're driving around town on a Saturday running errands. Stop and go traffic, hard acceleration, prolonged idling etc. All increase the under hood temps. I don't see how lifting the hood when you're done will increase the longevity of anything. Everything under there has already been subject to high heat for a prolonged period of time and was designed to survive it. Once you turn it off everything cools and is cooler than when the engine was running.
I agree with your wife & neighbors, keep your hood closed.
You've got me thinking... maybe it makes sense to drive around town with the hood unlatched to keep more air flowing through there. I think I'll try it tomorrow.
BTW, I used to drive a black vehicle and the hood would get "piping" hot, like a biscuit right out of the old wood stove. Anyway, I popped the hood a couple times, but I don't think it made any difference.
Wrong, the air needs to go thru the coolers in the front, not around them.. Get a cowl hood, it will let the hot air come out the back of the motor compartment...
Huh, it might also be unsafe to drive around with the hood unlatched
I've done this if I was going to work on a vehicle, figured the additional convection cooling would help cool it down faster. In a couple of cars I have added relays so I could turn on the electric cooling fans when stopped in traffic because I was concerned that the high temperatures would damage components such as the alternator. So, to reply to the original post, it makes sense, probably doesn't hurt anything. If it makes the neighbors think I'm crazy, maybe I'll start.
Here in sunny Phoenix Arizona with the temps in the 110 degree range, I usually open the hood when I get home to let the engine compartment cool down before I put the truck in the garage. If I don't, the garage gets really hot and stays that way until morning.
Now that makes sense! I can see doing that because when I lived where it was cold I would always try and do my garage type work after I got home since the still warm truck warmed up the garage.
When you say open, do you mean, like, fully open???
If fully open, I have a 100% WAG with absolutely nothing based on actual scientific evidence:
What about UV rays on rubber and plastic and wiring???
I KNOW for a fact that tires after a few years in the desert, even if they have tons of tread left, have little traction due to drying out......straight from a Toyo engineer at SEMA a few years ago after I axed him why I couldn't hook up in my '97 Cobra.
