Modular V10 (6.8l)
HELP !!!! I need some info PLEASE !
Old Apr 8, 2002 | 11:01 AM
ken04's Avatar
ken04
My axle code sticker on the drivers door says '34'. And my GVW says 9,600-10,300 (depending on axle ratio I'm guessing). But WHAT is this axle ratio ? I'm sure it's not a limited slip. I've been to the Ford site (wow, how UNhelpful was THAT). I've been to VIN decoding sites (they are for Rangers, F-150's, etc). I can't seem to get ANYONE to answer this. I posted on this website under 'axles, transmissions' but my post was 14,721 back from the first page so I doubt anyone saw it. Is there a site I can go to decode my '34' axle ratio ? Thanks, Ken
Old Apr 8, 2002 | 01:40 PM
Monsta's Avatar
Monsta
Sit. Stay.
I'm at work, so I do not have access to my CD right now.
Why don't you crawl under your truck and read the tag on the differential?
Old Apr 8, 2002 | 09:39 PM
steve nash's Avatar
steve nash
Check the tag on the rear cover it should say 3:73 4:10 4:30 depending on engine and pakage purchased
Old Apr 8, 2002 | 10:03 PM
Monsta's Avatar
Monsta
Sit. Stay.
OK, not to be toooooooo picky BUT...
It won't say anything with a colon between it. : <- That. The right way to write it is 4.30:1.
It will say 3 <space> 73 is the ratio is 3.73:1 or 3.73's. If there is an L after the 3, then you have an Limited Slip unit in the rear axle.
Same goes for 4.30's.
I found it easier by looking on the tag on my front diff. I also looked up your code. I do not have it listed. Are you sure you read it correctly? What year is your truck?
BTW Steve Nash, 4.10's are not available for the V10.
Although, I wouldn't mind having them...
Old Apr 9, 2002 | 09:08 AM
ken04's Avatar
ken04
Been down and around the pumpkin numerous times, but for the life of me, I don't see a tag. I know what they look like, I've checked all the other Fords I've ever had. And there's been LOTS of them. But for some reason there just isn't one on the big, white Supervan. So thanks in advance for all your help !! I have done numerous searches on the web, called my dealer (what a joke), looked on Fords site, and on and on. It doesn't seem like it should be this hard.
Old Apr 9, 2002 | 09:15 AM
NoMo's Avatar
NoMo
[updated:LAST EDITED ON 09-Apr-02 AT 10:16&nbsp;AM (EST)]I think the best options are:
a) consult the owner's manual if it still exists
b) crawl under the van and look at the axle tag- never mind you said it's not there!
c) call Ford customer service and see if they can help
Old Apr 9, 2002 | 05:04 PM
nevernuf's Avatar
nevernuf
Code 34 is a 3.73 NON LIMITED SLIP
Old Apr 9, 2002 | 05:33 PM
Monsta's Avatar
Monsta
Sit. Stay.
Nevernuf, good job!
Jen04, I had been looking under Super Duty/Excursion. I never looked under "van". I did when I got home tonight. I found it but nevernuf beat me to it!
Old Apr 10, 2002 | 09:30 AM
ken04's Avatar
ken04
Thanks Nevernuf, I appreciate your help. I suspected the 3:73 but needed to be sure. Thanks to everyone else who spent their time ! Ken
Old Apr 10, 2002 | 03:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sorry Ken, I called you Jen04. That is my wife's name: JEN. Musta been thinking about her right about then...
I shoulda known better though, my name is Ken.
Old Apr 10, 2002 | 10:03 PM
NoMo's Avatar
NoMo
A big to nevernuf!
Old Apr 12, 2002 | 07:47 AM
RockyMountain250's Avatar
RockyMountain250
