Window won't roll up
Old Aug 21, 2007 | 03:04 PM
Arnold Kenyon's Avatar
Arnold Kenyon
My driver side window takes anywhere from 2 to 15 seconds to roll up when I push the button. Has anyone replaced their switch in the door? How do you get to the switch to replace it?
Old Aug 21, 2007 | 03:18 PM
black04lariat's Avatar
black04lariat
It just pops up off the door panel. Get a flat panel tool underneath it and just pop it up.
Old Aug 21, 2007 | 05:07 PM
96f150's Avatar
96f150
Just curious as to why you think its the switch? More than likely its the window motor.
Old Aug 21, 2007 | 06:11 PM
mattd17's Avatar
mattd17
i would guess either the motor or regulator has gone bad.... since you are seeing movement when you push the switch, it sounds like that is working.
Old Aug 21, 2007 | 08:10 PM
awfulaggravated's Avatar
awfulaggravated
my dads o5 f150 xlt scc, did the samething you had to wait for sometime for the drivers window to raise took it back for warranty and they told him the switch was bad replaced it and problem solved
Old Sep 26, 2007 | 04:21 PM
Arnold Kenyon
I replaced the switch and that fixed the problem. I thought it was the switch because it acted like it was not getting a good connection when you pushed the button.
