Sponsored by: Real Truck
Spare tire size
Old Aug 21, 2007 | 02:41 PM
pspete's Avatar
pspete
Spare tire size
How important is it that your spare tire be the same size as the one it will be replacing in case of a flat? Can it be 2-3 inches smaller in diameter without causing serious issues? Thanks.
Old Aug 21, 2007 | 03:05 PM
Ed in Maine's Avatar
Ed in Maine
I run 285's and have a 265 spare. If it were any smaller and I had a flat tire up front, I would swap a full size from the back to the front and put the spare on the back. Only reason it would be an issue is if you had a sensitive locker in either diff.
Old Aug 21, 2007 | 03:11 PM
pspete's Avatar
pspete
Thanks for the reply.
Old Aug 21, 2007 | 03:31 PM
JustDucky's Avatar
JustDucky
If you have a limited slip rear diff. you would do the opposite. Put the small spare up front.
Old Aug 21, 2007 | 03:45 PM
Beerstalker's Avatar
Beerstalker
Like Just Ducky said, put the spare up front if you have a limited slip rear. Otherwise don't worry about it. It will probably dirve a little funny, but spare tires are just supposed to be used to get you to a place to fix your driving tire, not to drive on for extended periods of time anyway.
Old Dec 20, 2007 | 09:54 PM
oltrucker's Avatar
oltrucker
it can play hel with the abs brakes. the abs will see a sliding wheel and do its thing.
Old Dec 20, 2007 | 10:33 PM
thedaddycat's Avatar
thedaddycat
One advantage to having a matching spare(tire and wheel) is that you can do a five-wheel rotation. This will spread tire wear out over five instead of four tires and should yield 25% longer tire life. Granted it is a little more work...
