Sponsored by: Real Truck
ABS Light
Old May 6, 2007 | 05:32 AM
Excelerater's Avatar
Excelerater
ABS Light
300 miles into my trip my ABS light came on my
2006 PSD Dooly.......w only 5000 miles on the clock what could be wrong ?
im under warrenty but just wondering.....
Old May 6, 2007 | 06:21 AM
msgtg's Avatar
msgtg
Need more info....was it blinking or steady? Did it come on at startup and stay on or did it come on why driving? What were the conditions? Loaded or towing?
My first impression is that there is an electrical problem somewhere.
Old May 6, 2007 | 06:53 AM
Excelerater
I was towing,the light just stayed on.......
Old May 6, 2007 | 10:23 AM
wiingnut's Avatar
wiingnut
I had mine do that and there was a bad sensor somewhere I believe
Old Sep 21, 2007 | 03:02 PM
Rob.D's Avatar
Rob.D
Mine is doing the same thing, occasionally while towing. Either 2000# or 7000#, but it comes and goes as I turn the truck on and off. 10,000 miles on truck.
Old Sep 21, 2007 | 03:04 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is your speedometer also acting goofy?
Old Sep 21, 2007 | 03:14 PM
Rob.D's Avatar
Rob.D
It did last winter with about 4000 miles on it. I went up to the dealership and told them the speedo was all over the place. I had not drove the truck in about a month and it sit's in an unheated garage. The dealer said that the speedo acting up is a common thing, no fix other than driving it more.
Old Sep 21, 2007 | 03:19 PM
semperstrokin's Avatar
semperstrokin
I had a similar problem, mine would come on only after driving on log trips – couple hours or more. I just replaced my rear VSS Part # 6L3Z9E731A $74.44. It hasn’t come on since but I haven’t taken a long trip since, so I’ll just wait and see. I talked to a tech (trying to schedule a time, but they were backed up) and he said that they rarely see the front ones go out, for what that’s worth. Its only a 10min job, the sensor sits right on top of the pumpkin you cant miss it. You only need a 10mm (I think) socket. You also might get away with only just cleaning it.
_________________________
---------------- 2005 F250 XLT NO MODS
Old Sep 21, 2007 | 03:28 PM
redford's Avatar
redford
Bingo - the dealer SHOULD have replaced the VSS.
Speedometer acting up is not a common thing.
Old Sep 22, 2007 | 06:21 AM
Green_Monster's Avatar
Green_Monster
I have had a similar problem helping my buddy with his 99 f350 srw. He has replaced the VSS,( the old one looked fried) drained and cleaned the rear diff and for some reason his speedometer likes to sit at 40 mph or work fine?
Any thoughts? Bad cluster? Bad Ground?
Old Dec 19, 2007 | 12:40 PM
blakerj10's Avatar
blakerj10
Green Monster. I am in the same shoes as what you described. Mine has happened many times before, but this time I am out of warrenty. What did your friend figure out?
Old Dec 19, 2007 | 01:25 PM
Green_Monster
unfortunately I think he determined it was the cluster but not 100%, I will ask him at work tomorrow night and let you know
Old Dec 19, 2007 | 01:54 PM
blakerj10's Avatar
blakerj10
Ughh, not what I wanted to hear! I wil patiently await your follow-up.
Thanks
Old Dec 19, 2007 | 02:06 PM
boone1965's Avatar
boone1965
Have them check both VSS's. One is in your Tranny and there is one in the Rear Diff. I bought the one in the rear diff at AutoZone for 25$ or so and used a metric size wrench to replace mine. Done in about 15 min. the dealer was going to check both of mine and the cluster...for some ridiculous amount..
I got the trouble shooting from this very forum and it has saved me a lot of $ in mainteneace costs at the dealership!
Mine did the same thing on a trip with a trailer from Birmingham.
Old Dec 19, 2007 | 02:28 PM
blakerj10's Avatar
blakerj10
I ordered BRAB130 model sensor for the diff... turns out it is the wrong one for mine. I need a 6L3Z9E731-A according to the dealer and you can't get this one at auto zone. Dealer only. Yeah, it is a 10 mm bolt and easy to change. I hope it is this sensor ($85 dealer price) rather than the cluster (again).
I don't think the 6-speed manual has another speed sensor on it?
