Shift on the fly not working
Old Aug 21, 2007 | 08:39 AM
f350rebel's Avatar
f350rebel
Cool Shift on the fly not working
I just noticed that my shift on the fly doesnt work...I noticed because i took te back driveshaft off and had the truck in 4x4 AND ABOUT GOT RAN OVER!!!!! I had to stop the truck by pushing back on it before it crushed my dads 05 ranger..
Anyways when i manually lock in the hubs my 4x4 works, but not when i shift on the fly...What could be broke and how do i go about fixing it?
Old Aug 21, 2007 | 08:42 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I had the same problem on my 01', it turned out to be a vacuum hose at one of the wheels. Check for a broken hose or one that is dry rotted. Dealer said that was a common problem. You may have more problems than this. Good luck.
Old Aug 21, 2007 | 08:45 AM
f350rebel's Avatar
f350rebel
where does the hose do into the wheel from?
Old Aug 21, 2007 | 10:16 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Another option is to replace the factory hubs with the Warn Premium manual locking hubs (part# 38826). It takes about 30 minutes. Then plug the supply air line to and from the ESOF silenoid, located behind the passenger side battery mounted on the fender. You have to get out of the truck to lock the hubs but its reliable. Do a search on "Warn Hubs" and you'll get all kinds of information.
Old Aug 21, 2007 | 10:35 AM
f350rebel's Avatar
f350rebel
when i bought the truck the guy told me it had warn hubs, but i thought that the shift on the fly would still work with the warn ones.....
Old Aug 21, 2007 | 10:46 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
When you work the switch does your A/C default to defrost?
Dumb question I know but try it and see. If it does then you have a vacuum leak and that is your problem.
Old Aug 21, 2007 | 10:47 AM
wlihntr's Avatar
wlihntr
nope...if it has warn hubs they are manual only
Old Aug 21, 2007 | 10:53 AM
f350rebel's Avatar
f350rebel
how can i tell by looking at them should they say warn on the **** that i turn
Old Aug 21, 2007 | 11:07 AM
Texas Outlaw
Not a liberal...
Do they look like this?
Old Aug 21, 2007 | 11:08 AM
f350rebel's Avatar
f350rebel
NOpe i think i was lied too.... The **** is black no chrome or brass colors
Old Aug 21, 2007 | 11:50 AM
Texas Outlaw
Not a liberal...
Sounds like stock hubs to me. Can you take a pic and post? If not I can snap one of mine and post.
Old Aug 21, 2007 | 11:59 AM
f350rebel's Avatar
f350rebel
my girlfriend has my digital camera.....it is black with a chrome/silver piece in the middle of the ****... i think it is stock
Old Aug 21, 2007 | 12:43 PM
Texas Outlaw
Not a liberal...
Here's my right front. Stock.
Old Aug 21, 2007 | 12:51 PM
f350rebel's Avatar
f350rebel
i have the same
Old Aug 21, 2007 | 12:54 PM
Texas Outlaw
Not a liberal...
Try that A/C trick and see what happens. Chances are you have a vacuum leak at the hoses.
