mounting maglite, can't get though floor
Old Aug 20, 2007 | 09:18 PM
tomtoc's Avatar
tomtoc
tried to mount my maglite in the truck last weekend. in my ranger i put it next to the driver's seat. having more room in the 250, i wanted to put it up on the center hump, just under the dash.
in my ranger i went through the floor with some screws no problem. i'm trying to mount this C clamp charging deal that cradles it. problem is i can't get through the floor. am i using the wrong bits?
flashlight link: http://maglite.com/product.asp?psc=RECHARGE
tried it next the the driver's seat too and same issue. made it through where i put it on the door, but the light kept falling out of the holder when i shut the door.
Old Aug 21, 2007 | 12:27 PM
lostin90s's Avatar
lostin90s
Should just be sheet metal on hump . Other than possible access cover (doulbe thinkness) I just mounted a homemade console and used 4 self tapping screw to mount it. But good luck
Old Aug 21, 2007 | 12:35 PM
tomtoc's Avatar
tomtoc
odd, i can feel the drill go though the carpet, hit metal then just sit and spin. did it fine in my ranger, i wonder what the deal is.
Old Aug 21, 2007 | 12:47 PM
wassabe's Avatar
wassabe
Well, it could be you are using the wrong type of bit, or the bit is dull. Now don't take this the wrong way but is the drill motor in the forward position? I'm sure you checked that, and it may seem like a stupid question, but I've done it myself a few times.
Old Aug 21, 2007 | 12:49 PM
tomtoc's Avatar
tomtoc
i've got a practically brand new bit set. they're all 99% sharp, tried the different kinds of bits (wood, metal, etc). and yes, valid question, but drill is in correct direction
Old Aug 21, 2007 | 12:53 PM
Skandocious's Avatar
Skandocious
I assume you are drilling pilot holes before trying to tap the screws right? If not, that would make your life a whole lot easier...
I've drilled through the sheet metal in the door panels to mount speakers and also did it this weekend on the inside fender of the engine compartment to mount my relays, it does take some muscle and a bit of patience... It will feel like the bit is not moving but it is, you just gotta keep at it.
Old Aug 21, 2007 | 12:56 PM
tomtoc's Avatar
tomtoc
yea, holding up the plate it mounts on (with holes for screws in it) and putting the drill bit through there. i'll try again tonight because just thinking about it i'm getting more frustrated.
Old Aug 21, 2007 | 01:04 PM
i1dery's Avatar
i1dery
Well maybe you have already drilled thru the floor and your now attempting to
go thru the tranny.
Old Aug 21, 2007 | 01:07 PM
Skandocious
Hahah! I sure hope not!
Old Aug 21, 2007 | 01:31 PM
tomtoc's Avatar
tomtoc
go thru the tranny.
no it definately goes through the carpet real quick then just sits and spins if the bit comes out red i'll let you guys konw
Old Aug 21, 2007 | 03:14 PM
alz's Avatar
alz
Is the bit getting wadded up with carpet?
Old Aug 21, 2007 | 04:30 PM
Wild Karrde's Avatar
Wild Karrde
Sits and spins... Sorry, I just had to laugh at that.
Try starting your hole with a much smaller bit, then re-drilling it with a larger one. I just got finished with drilling holes in my bed for mounting some "tailgate latches" (please don't ask, it's a very long story), and found it much easier if I did it this way.
The only other thing I can suggest is, cut a tiny bit of your carpet away. Just large enough to see what you're doing against the metal, but not enough to show when you mount your maglite. This will allow you to see how far into the metal you're working, and show if you have something odd in the way. Some of these trucks came with an odd "insulation" between the carpet and the floor, and it's possible that's screwing things up for you.
Plus, some parts of these trucks have thicker sheetmetal than you'd ever think possible...
Old Aug 21, 2007 | 04:54 PM
handyman43358's Avatar
handyman43358
Haha I'm glad I wasn't the only one who caught that! And I doubt he's hitting the tranny... because he would be inside that quicker than he got through the carpet! Aluminum is soft! I know you were joking about that... but before someone read that and freaked out, I figured I'd point that out.
Tom, I think what you're experiencing here is a battle of drill bit versus heavy metal! If this was a... Toyota, for instance... you probably could have gone through that with a 5/8 paddle bit in 3 seconds. I'm honestly suprised that the bit hasn't grabbed the carpet and sent it twisting up into the drill yet!
Old Aug 21, 2007 | 05:10 PM
tomtoc's Avatar
tomtoc
got it worked out thanks guys. not really sure what wasn't doing the trick before but cursing and sweating more seemed to get it done this time.
carpet was coming up the bit, but nothing too bad. i had to really dig out the insulation crap below b/c i was having a hard time finding it with the screw once i took the bit out.
pic:
next step: wiring it up to a switch to control when it charges.
EDIT: it's level, just looks funny from the angle i guess
Old Aug 21, 2007 | 05:38 PM
Skandocious
Hmmmmmm.....
TOLDJA SO!
