powertrain control module
Old Aug 20, 2007 | 08:34 PM
Wayland's Avatar
Wayland
I need to replace my 99 ford f350 diesel powertrain control module. Any suggestions, do or don't would be appreciated. Wayland
Old Aug 20, 2007 | 09:03 PM
John311t's Avatar
John311t
Why do you want to replace it?
Old Aug 20, 2007 | 09:10 PM
Wayland's Avatar
Wayland
The truck won't start and I replaced the CPS. Also the OBD tool shows no codes. I had the truck towed to the ford dealer but I am having it towed home tommorrow. The dealer has diagnosed this as the problem and the cost to replace this is $2,500. I am going to buy a new module tommorrow for $750. and try to replace myself. Wayland
Old Aug 20, 2007 | 09:51 PM
Benny2002's Avatar
Benny2002
That seems a little steep for a PCM, where are you buying it from?
Old Aug 21, 2007 | 06:24 AM
John311t's Avatar
John311t
I belive the best pcm code is PMT-2. Though im not 100%sure. Its pretty straight forward to replace.
Old Aug 21, 2007 | 07:59 AM
bdrummonds's Avatar
bdrummonds
Call Jody at Dp and order one of his with a tune on it. much cheaper than 750
look here http://www.dp-tuner.com/73tuning.htm about 1/2 way down the page.
Old Aug 21, 2007 | 08:59 PM
Wayland's Avatar
Wayland
It cost me $626.00 to buy the new one at a local okc parts distribution warehouse, but today when I got home it was the wrong one. I will pick up the right one tommorrow. I was able to get the old one out without removing the inside cover to the right front fender well but I may have to remove it tommorrow when I get the new one in order to install it. Wayland
Old Aug 21, 2007 | 09:06 PM
bdrummonds's Avatar
bdrummonds
Are you talking about the IDM (injector driver module) under fender skin or the PCM(under the dash behind e-brake?)
If its IDM, 6 bills aint bad, if its PCM then way too much.
Old Aug 21, 2007 | 09:49 PM
justblowin'smoke's Avatar
justblowin'smoke
i paid 300 for my pcm plus the old one
Old Aug 22, 2007 | 09:50 PM
Wayland's Avatar
Wayland
mibad, It is the IDM, I replaced it tonight. My truck runs now, but the service engine soon light stays on and the truck is running really rough. Tommorrow I will bring home a OBD and see if I can figure out whats wrong. Getting to the IDM (not the power control module) was fairly easy after I removed the front fender well, and I'm glad I replaced it instead of paying the $2,496 the dealer had qouted.
Old Aug 22, 2007 | 09:53 PM
Benny2002's Avatar
Benny2002
Check the harness under the valve cover you may be shorting out the uvc harness a little. I think the 99s didnt have the shim to keep them from shorting if the come loose. Theres an OHM trick to know which side but someone else will have to tell you that
Old Aug 22, 2007 | 10:22 PM
Benny2002's Avatar
Benny2002
This is what u should check for...
https://www.ford-trucks.com/lc/lc.ph...icle-05-10.php
https://www.ford-trucks.com/lc/lc.ph...60109924rsWjOG
Old Aug 23, 2007 | 09:10 PM
Wayland's Avatar
Wayland
Thanks for the website referral. I bought two new uvc harness today and I am going to replace them tommorrow evening & saturday. The orginal dealer that qouted my repair said they had ohm them out and both were bad and they were going to replace them along with my IDM. When I bought the uvc harnesses today they did not say anything about the shim but I will check tommorrow.
Old Aug 23, 2007 | 10:17 PM
Benny2002's Avatar
Benny2002
Im not sure if the shim is stock or what guys have done to ensure the connectors dont come apart, i havent been under mine to see whats what. If you got new harnesses you might not need it Good luck hope that cures ur mule.
Old Aug 24, 2007 | 06:33 AM
bdrummonds's Avatar
bdrummonds
Ford actually changed the design of the clips(on the harness) to integrate this feature in 01 IIRC. So you should not need a shim.
