EGR Diagnosis Suggestions?
OK, so here is the story...About 10 months ago, my check engine light came on. I read the code and got 401:EGR flow insufficient. So I mess around with the EGR and it seems to be fine. I play with my multimeter for a while and decide that I need to replace the DPFE sensor. I replace the sensor and have the battery disconnected to clear the computer. When I started her up again it seemed fine and has been fine since.
Last week, my check engine light came on again. I get the code read and it is the same thing 401. I think it is highly improbable that the DPFE sensor is bad again in only 8 months. I used a vacuum pump and messed with the EGR and it seems to be working fine. The engine still runs fine but at times seems a little sputtery. No stalling at idle or on a cold start.
When I read the VREF on the harness side of the DPFE sensor it was not between 4-6 Volts. Any suggestions as to what I can test or look at next. I don't want to have to replace the PCM because that costs like $150.
Any help would be greatly appreciated. Thanks!!
artfd
1997 - 2003 F150
50
11-29-2017 06:37 PM
Al_Cuevas
1997 - 2003 F150
93
08-13-2016 08:50 AM
YellowXLT
07-05-2015 06:09 PM
