Help with gas leak
Old Aug 20, 2007 | 06:41 AM
zbop00's Avatar
zbop00
Help with gas leak
Unbelievable as this sounds, I was smelling gas from my 94 ranger. Mechanic removed the bed and said the neck from the tank to the filler neck is split. Went to junk yard and 2 there were split in the same spot. Dealer price for new one is 375.00. Does anyone know if there is an aftermarket one or what I can use to repair the old one?
Z
Old Aug 20, 2007 | 10:52 AM
customstringer's Avatar
customstringer
This is an unfortunate frequent problem with Rangers. Have you tried the sponsor of this forum for Ford parts, http://www.discountfordpartsaty2kford.com/. The neck for my Ranger was considerably cheaper, but not cheap. Other than that if you want to stick with salvage part, why not try one of the online yards and make it clear to them you need one that is intact.
Old Aug 20, 2007 | 01:19 PM
zbop00's Avatar
zbop00
Neck
Is the neck online the entire length from tank to cap? I haven't seen the break yet (tonight hopefully) but Mechanic said it was right at the tank.
Z
Old Aug 20, 2007 | 03:13 PM
customstringer
Appears so see No. 6 on drawing
Old Aug 21, 2007 | 12:58 AM
Pablo-UA's Avatar
Pablo-UA
Neck craks becouse of bed vibration. Unfortunatly sometimes it is impossible to fix. New tank is expencive. One gue in our shop fixed it with glue.
Old Aug 27, 2007 | 01:35 PM
zbop00's Avatar
zbop00
Easy fix
After pulling the bed and removing the neck the crack was in the rubber part of the hose. I just simply cleaned it up and used rubber cement to seal the crack. Then I used electrical tape to wrap the area to hold it until the cement dried. It also will help it not crack again (I hope.)
Z
Old Aug 27, 2007 | 01:53 PM
customstringer
I hope so too, good luck.
kevin-11
52
Mar 22, 2016 12:40 AM
okwaho1650
Mar 2, 2012 09:00 AM
hivolt5.0
Jun 12, 2008 04:07 PM
maevans
28
Jan 15, 2006 12:10 PM
wmodon
Aug 16, 2004 07:50 PM
