Torque converter clutch?
Old Aug 19, 2007 | 10:07 PM
Skandocious's Avatar
Skandocious
So after a long, hot, trafficky trip back to Davis today I checked the temp of my torque converter with an IR temp gun, 170-180*, sounds about right.... right?
Anywho, parked it and did some work for a couple hours, got back in and started driving home. I noticed that at low speeds if I suddenly let completely off the gas, the engine would silence for a split second and sound like its gonna die, then spring back up to idling speed. It happened several times but VERY quickly, almost undetectable. Is this a problem with my TC clutch not disengaging quickly enough?
Old Aug 19, 2007 | 11:55 PM
Wild Karrde's Avatar
Wild Karrde
How low of speeds are we talking about here? If it's low enough to "idle" when you let off the gas, I sincerely doubt your TCC is even engaged at this point. They usually don't engage until you reach a "cruising speed" (they kind of act like an extra gear in your transmission, but not), and if it engages sooner than that, you've probably got a problem.
I would honestly think it to be more of an engine issue than a transmission issue at this point. If you're travelling fast enough for the TCC to engage, when you let off the fuel, it shouldn't drop down to idle in an automatic.
Old Aug 19, 2007 | 11:58 PM
Skandocious
Ahhh, well this is at low speed but your comment at the end makes me wonder:
Lately I have noticed that my RPMs are not falling back down to an idle when I let off the gas.... But it also doesn't exactly feel like I'm riding a gear down like a manual transmission (TCC locked up). Is there a sure fire way to diagnose the TCC?
Old Aug 20, 2007 | 12:13 AM
Wild Karrde
When I diagnosed a TCC issue in my IROC, I wired a toggle switch (one side to a hot wire, the other in place of the wire that goes into the plug on the transmission) so I could manually control TCC lockup. Some people will do this on their "street racers" to bypass TCC lockup entirely, or to be able to use it only when they want to.
After I did this, I found out that I did have a bad TCC (or at least the controller for it). When I left it engaged all the time, it did the exact same thing as it did before I wired the switch, but when I disengaged it at lower speeds, the car drove like it was supposed to.
I can't honestly say this would be a good permanent fix, but it DOES work to test it. Find in a shop manual or online which wire on your transmission is the TCC lockup control and replace it with a toggle (or you could actually just unplug that one wire and test it that way if you don't want to run a switch). If when disabled, your truck drives like normal at low speeds, it's probably the TCC. If not, it's most likely something else.
Old Aug 20, 2007 | 12:29 AM
Skandocious
Yeah I kinda figured a lockup switch was in order... I attempted it a few weeks ago but tapped into the wrong wire because the wire colors were so faded. No damage done to the truck. I suppose I'll have another crack at it for testing purposes. Thanks.
Old Aug 20, 2007 | 12:32 AM
Wild Karrde
Not a problem. Let me know what you find out!
Old Aug 20, 2007 | 10:34 AM
351slug's Avatar
351slug
I have a 93 F-150 351W E4Od and put a toggle switch to control Lockup TC. It works well. Its the Pink and white wire. Subford can tell you more. I need to install lower gears for my 35s but if I cut off lockup converter, it feels faster. If im not playing I leave it alone for gas milage.
wantaford
Utah Chapter
Nov 24, 2011 02:44 PM
BuickTurbo
Jun 17, 2007 03:34 PM
saltwaterman
20
Jan 4, 2006 07:45 PM
99stocksport
Exhaust Systems
Jan 10, 2005 09:31 PM
davie
Dec 16, 2001 09:38 AM
