Econoline glass seals
Old 08-10-2007, 05:30 PM
Ole' Green's Avatar
Ole' Green
Ole' Green is offline
I'm just finishing up the paint job on my '64 econoline van. Its an old work van and only has windows in the rear. I've been looking for window rubber and keep running across the option "with notch" or "without notch".
Not sure what the notch would be. Are they referring to windows that pop out and the latch would cause a notch in the weatherstrip? Or is it something else? Any help would be appreciated.
Old 08-10-2007, 06:04 PM
rocking-b's Avatar
rocking-b
rocking-b is offline
GOT ANY ECONOLINE PARTS LAYINIG ABOUT? I need alott of the interior *****, heater hoses, steering wheels etc....
Old 08-10-2007, 08:47 PM
Ole' Green's Avatar
Ole' Green
I have a shop full of parts...but they all go back on as soon as the paint is dry. Sorry. I'll be looking for some interior door handles soon. I'm wondering if early mustang hardware would fit since its so abundant. Econoline parts are so hard to come by.
Are you piecing yours together after a restore, or just trying to get it in shape?
Old 08-10-2007, 09:05 PM
rocking-b's Avatar
rocking-b
I found this one out in the desert, body very good, but alott of the interior *****, switches, heater hoses, glass, steering wheel, interior stuff needs to be REplaced or just plain PLACED back where it WAS. The 240 IL6 is being replaced with a hi-po 289 and a 4 spd auto c-6 with a 9" ford. I have a 8.8 2.73 LS FORD to go under it but it is too short. someone on here looked up the tag numbers for me, thats how i know about the rear end.
Old 08-13-2007, 04:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Ole' Green
I have a shop full of parts...but they all go back on as soon as the paint is dry. Sorry. I'll be looking for some interior door handles soon. I'm wondering if early mustang hardware would fit since its so abundant. Econoline parts are so hard to come by.interior
Mustang door/window handles won't work on an Econoline. Econolines use a set screw to hold the handles on. Mustang handles have a Phillips screw that goes directly through the handle into the window regulator or door remote control.
Econoline interior door and window handles aren't that hard to find, here's why:
B7C-8122600-B .. Door Handle - Fits: 1961/67 Econoline; 1957/66 F100/1100, 1957/79 C550/1000 (flat nosed tilt cab); 1967/69 F/N/NT500/1000
C1TZ-8123342-A .. Window Handle - Fits: 1961/67 Econoline; 1961/66 F100/1100; 1957/79 C550/1000; and dozens of other BIG trucks.
2-C2UZ-8941954-A .. Back Door Window Weatherstrip-FIXED Window ~ 1961/67.
2-C1UZ-89262A80-A .. Back Door Window Weatherstrip-Outer-MOVABLE-Window ~ 1961/67.
These are the only weatherstrips listed for the back door windows.
Old 08-13-2007, 07:13 AM
rocking-b's Avatar
rocking-b
Bill.....I need a e-100 [econoline] pre-65 tail gate, could I use a reg ford tail gate, the ones with the chain and hook on the sides? thanks in advance
Old 08-13-2007, 01:01 PM
NumberDummy
Econoline ONLY, and there are two different ones. One is lower than the other.
Both tailgates fit 1961/67.
HIGH: C2UZ-8740702-A ~ 50 3/4" x 23 1/2"
LOW: C2UZ-8740702-B ~ 50 3/4" x 19 1/2"
Parts catalog sez: Measurements are approximate.
Old 08-13-2007, 05:12 PM
rocking-b's Avatar
rocking-b
I am impressed !!! Lucky for this human sub-group to find sporaticly a walking encyclopedia of historical information and technology! Thank you.........Paul
Old 08-21-2007, 12:09 PM
Ole' Green's Avatar
Ole' Green
NumberDummy,
Thanks for the part numbers. The manufacturer that I'm going thru lists two different part numbers for the fixed rear window weatherstripping. C2UZ8941954-A is described as "rear glass fixed, with notch". C2UZ8941954-C is described as "rear glass fixed, without notch".
Any ideas what this notch is that they refer to?
I'm also ordering the windshield rubber, is this part number in line with what you have? C1UB8903110A
Thanks for the help.
Old 08-21-2007, 06:42 PM
66gpw's Avatar
66gpw
66gpw is offline
Those numbers sound like the parts numbers from Dennis Carpenter in North Carolina. His business has a toll free number if you can find it. Maybe give him a call and they can explain it for you you. I have a catalog from 1991 from them and those numbers match in his catalog, but no explaination as to the difference.
I presume the difference is that the notched ones are for windows that open and the non notch are for fixed windows that do not open.The notched rubber is most likely for the window latches.
Give his shop a call. They are not that far from you in Florida.
Old 08-21-2007, 08:36 PM
rocking-b's Avatar
rocking-b
this is like playing..."FISH".......anyone got a tail gate?....."go fish"!......anyone got a v/8 engine support cross member?
Old 08-21-2007, 09:49 PM
66gpw's Avatar
66gpw
66gpw is offline
Those tailgates are gold and when you have one no matter the condition you want to keep them. Someone might let one go. I have 2 and will be needing them for my two projects. Good luck on your fishing.
Old 08-22-2007, 02:04 PM
Ole' Green's Avatar
Ole' Green
Well, I figured out the "notch" issue. There is a flange that the glass sets against, where the weatherstrip fits over. Some flanges are straight and flat and some have a lip that curls toward the inside of the van. This little lip is referred to as the notch. Mine has the notch.
My buddy Joe posted a picture of my van in the '48 - '60 f100 forum, the title is first paint job. He's a little more savvy than I am with the pictures, but I'll get my gallery up shortly. We just finished painting it on Thusday night, now I'm piecing it back together.
Thanks for all of the help.
See if this link works.
https://www.ford-trucks.com/forums/6...paint-job.html
Mtnhaul
03-21-2016 12:20 AM
65 Econoline
02-21-2016 02:22 PM
alarmmedic
47
11-03-2013 07:59 PM
tigerfan79
11-05-2012 09:47 PM
JimAllen
04-14-2007 09:39 PM
Quick Reply: Econoline glass seals
