C Notch Question
Old Nov 4, 2012 | 09:11 PM
tigerfan79's Avatar
tigerfan79
C Notch Question
I have the Chassis Engineering rear leaf spring kit for my '51 and am using an explorer rear axle. Mocking everything up I'm thinking I may want a small notch just to be safe on travel. I found this universal bolt in notch and was wondering if it would work or of anyone has used it before:
Bolt-in C-Notch Kit | thorbros.com
Thanks,
Matt
Old Nov 4, 2012 | 10:01 PM
52 Merc's Avatar
52 Merc
Personally, I don't care for the looks of it if you're running leaf springs. You're cutting a hole in the bottom of the rail and a big notch up the side without anything to tie it all back together solidly. I'd want the bottom rail welded to the bottom of the C notches, and the inside boxed together to put the strength back in you removed. That's my 2c.
Old Nov 5, 2012 | 01:29 PM
AXracer's Avatar
AXracer
Those should be strong enough to work. Makes sure you don't cut away any more than necessary to fit them in and put a bolt in every hole. if it was me, I'd weld the cut ends of the lower frame flange to the U piece.
Old Nov 5, 2012 | 05:05 PM
tigerfan79's Avatar
tigerfan79
I definitely have my doubts about it, thanks for the responses. I agree with welding the frame lip to it that's a good idea. If I decide to use it, would it be of any benefit to cut out a similar piece (with the notch cut out) and bolt it on the backside of the frame? That way it would be the c notch, then the frame rail, and then a cutout mimicking the shape of the original notch kit (frame rail sandwiched in between all bolted together)?
Old Nov 5, 2012 | 06:10 PM
TireDood's Avatar
TireDood
How good are your welding and fabrication skills? If you can handle the basics you could do something like this
for a lot less.
Keep in mind that I still need to box the frame before and after the notch. I'm waiting until I get the gas tank in to do that. The metal cost me about $20, and it took about 6 hours to fabricate and install...
If you would like more pics or dimensions just let me know....
Old Nov 5, 2012 | 09:47 PM
AXracer's Avatar
AXracer
An 1/8" thick doubler on the inside of the frame certainly wouldn't hurt anything. I like the tab from the top of the notch to the top frame lip TireDood used. An inside boxing plate from 6" in front to 6" behind the notch would be the ideal solution, but I assume you are trying to avoid welding.
Here's the way I do C notches deeper than 1/3 the frame height: Note inside of frame is boxed before notching.
Showpanther
Mar 9, 2015 03:19 PM
ulev1st
Sep 15, 2013 03:02 PM
abashee
16
Feb 8, 2011 01:01 AM
Knucklebuster
31
Aug 20, 2006 07:22 PM
F100man
Feb 5, 2006 11:48 AM
