Dometic refig recall
Old Aug 19, 2007 | 07:26 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If you have a Dometic Refigerator made between 4/97 and 5/03 and it is a 2 door model.
Go to www.DometicUSA.com for more information.
Old Aug 19, 2007 | 07:50 PM
IDMooseMan's Avatar
IDMooseMan
Thanks for the info, BigRedTruckMI. My TT is a 1991, so if you hear of anything for them, please let me know.
Old Aug 19, 2007 | 08:03 PM
bigredtruckmi
Veteran: Navy
I saw this in Trailer life magazine pg 20 in Sept 07 edition.
Also the toll free # is 888-446-5157 for Dometic.
Old Aug 19, 2007 | 09:17 PM
IDMooseMan's Avatar
IDMooseMan
Thanks again, Red. Rep points sent.
Old Aug 19, 2007 | 11:02 PM
c.f.moore's Avatar
c.f.moore
I had the recall done on my '03 Alpenlite fifthwheel. Watched the "upgrade" being done. Basically they install a sheetmetal housing around the burner portion of the propane section of the refrigerator. Then they add a sensor above the burner, so if a fire starts in the burner area, the sensor shuts off the propane. This is all "good" if the fire has not started burning something other than propane.
The "upgrade" makes servicing/cleaning the burner a PITA.
Old Aug 20, 2007 | 08:51 AM
Kwikkordead's Avatar
Kwikkordead
They put a whole new burner assembly in mine along with the shield.
Something about possible cracking of the burner assembly and it had to be replaced.
Old Aug 22, 2007 | 06:52 PM
jwearly's Avatar
jwearly
Had recall upgrade done on my 03 Keystone Cougar. Had problem with GAS operation afterwards.m Turned out to be gas starved, needed to opurge gas line. Cost $50.00 at local Camping world.
Wife raised "HOLY HELL" with store manager because they installed Recall kit. Got store to refund $58.00.
BPofMD
All Things Towing
Nov 15, 2014 08:47 AM
BeerCan500
All Things Towing
Sep 3, 2012 07:18 PM
shorebird
All Things Towing
Jan 25, 2009 11:57 AM
Kep4
All Things Towing
24
Dec 15, 2007 09:52 PM
jwearly
All Things Towing
May 28, 2007 04:41 PM
