Thermostat install?
Old Aug 19, 2007 | 06:10 PM
TJC's Avatar
TJC
Lightbulb Thermostat install?
I figure I would ask here before I trust the manual to put in a new Thermostat on my '86 F-250. Who's done it and how? I have a Chilton's but have found that the manual can have extra steps that are unecessary for doing the job. If anyone can give me a little guidance or tell me a few tricks to make it easier I'm all ears.
TJC
TJC
Old Aug 19, 2007 | 06:27 PM
bikergerm's Avatar
bikergerm
It looks pretty simple, I would remove the upper hose from the thermostat housing to make it easier to clear the filter base. Use RTV when installing the gasket.
Jeremy
Old Aug 19, 2007 | 07:15 PM
Brimmstone's Avatar
Brimmstone
I've found it's easiest just to pull the alternator, vacuum pump, and the mounting bracket for the pair. I can have them off in under 5 minutes then the goose neck is open and accessible
Old Aug 19, 2007 | 07:20 PM
PLC7.3's Avatar
PLC7.3
My info is for later years but some info is usable........
CAUTION:
The specified/required thermostat does not contain an internal bypass, since the bypass is located in the cylinder block. Whenever the thermostat is replaced, it is mandatory that only Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat be installed.
CAUTION:
Do not attempt to repair any thermostat. It should be replaced if it is not operating properly.
Check the new thermostat before installing it for correct opening temperature. Before suspending in boiling water, with a flashlight check where the rubber and the flat metal flange meet for bad seal. Tstat should start to opening barely at 180-192f, fully open 200-212f, allow to cool and check for rubber seal again.
Removal: Disconnect batteries, drain 4+ gals A/F, remove: as required, fan belt, alternator set aside, alt bracket, remove filter support from fuel filter then e/block. Disconnect upper rad hose at rad, remove tstat bolts and housing. Clean both faces, depression and holes in block, ensure check ball in goosekneck is clean, free and rattles "do not remove".
Installation is reverse proceedure, I do not use sealant on gaskets and faces. REMEMBER the tstat pellet(copper end) goes into the block. I do use a "very small amount" of sealant on the edge of the tstat face when installing into the recess, now go for coffee, allow sealant to setup, this has saved me from tstat slippage when the gasket and goosekneck are installed. Replace all items in reverse order......
Manifold bolt torque......... 20ftlbs
tjc transport
May 27, 2013 05:59 PM
tjc transport
Garage & Workshop
Apr 23, 2011 11:15 AM
tjc transport
Sep 20, 2010 07:18 PM
tjc transport
Jul 8, 2009 02:25 PM
