Sponsored by: Real Truck
Need driveshaft help now!!!!
Old Aug 19, 2007 | 06:00 PM
f350rebel's Avatar
f350rebel
I removed the back part of the driveshaft to get it fixed, but do i need to remove the shaft that goes through the carrier bearing.... I'm going to get it all replaced i was just wondering if i could run it in four wheel drive (Front wheel drive) and not have to worry about that shaft causing any damage... Also will it hurt to not have any force on the pinion while the wheels are turning....Thanks
Old Aug 19, 2007 | 07:01 PM
Whit350's Avatar
Whit350
I did it for about 6 months in my 94 toyota, it worked fine but it wasn't much fun to drive. I Don't know about the Ford. good luck
Old Aug 19, 2007 | 08:24 PM
PupnDuck's Avatar
PupnDuck
Its going to handle funny, particularly when going around corners (torque steer) but you can probably get away with it for a short time. Keep your foot out of it though - the front end was never designed to handle that much power. If you get heavy-footed it will make expensive noises!
Old Aug 20, 2007 | 04:15 PM
f350rebel's Avatar
f350rebel
i'm only going to drive it over to the machine shop and then they are going to make me a custom shaft so i wont be romping on it or driving it for a long time
