Auto Locking Hub Problems
Old Aug 19, 2007 | 04:58 PM
usa52201's Avatar
usa52201
I have a 2000 Excursion and when I go into 4X4 it is not engaging the frount wheels. When I get out an manualy lock the hubs then I get 4X4.
So do I need to replace the hubs?
If so should I use something other than the factory part to get better preformance or strength?
Thanks
Old Aug 19, 2007 | 08:29 PM
snurtle112's Avatar
snurtle112
sounds like the vaccum is not working to engage..IMO
Old Aug 19, 2007 | 09:34 PM
1's Avatar
I agree the vacuum system is propbably having some sort of problem. Fairly common im sure if you check out the search feature youd find lots of good info. I havent had the problem yet though so i cant give any firsthand advice.
Old Aug 20, 2007 | 12:04 AM
RACERX7775's Avatar
RACERX7775
i had 1 that was staying locked. i removed them and bought a set of mile marker manual hubs. part #449SS. i love them. pics in my gallery.
Old Aug 20, 2007 | 01:34 AM
emptyd's Avatar
emptyd
Several people have already mentioned a vacuum problem. One symptom of this is that the air flow dampers don't work correctly, expecially when the engine is under load.
If you set the air to come out of the vents and step on the pedal, the airflow may switch to the defrost. This is because the dampers are manipulated by vacuum and the vacuum presure drops when the engine revs.
This was the symptom I had. If it is a vacuum leak, do the easy stuff first. Check the lines that run to the hubs since they are exposed to road hazards. There is a vacuum control solenoid for the hubs under the hood that can go bad. This was my problem, but I don't know exactly where it was - the dealer found and fixed it. But they first ripped apart the dash looking for a leak in the damper control system. Poor choice! Check the easy stuff first.
The tech told me that under load, the vacuum drops to about 2 psi - if I recall correctly. So if there is a leak, there isn't much room before things stop working.
Hope this helps
cattlerancher
Nov 27, 2014 08:43 PM
BarryOwings
Mar 27, 2014 04:19 PM
winginit
Jan 4, 2014 09:24 AM
Ummms
Mar 24, 2011 04:45 PM
gordo2
Offroad & 4x4
15
Mar 29, 2010 10:09 AM
