Thinking about a new cam - help please
Old Aug 25, 2007 | 12:46 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Yup you did, your azz backwards.
Advancing cam increases dynamic compression and low end torque, retarding cam for more top end power with a loss of low end.
Advancing cam more than 4 degrees off spec can cause detonation problems as well a power loss. Try different cam timing combinations on a Dyno Sim program you'll be surprised one degree can make a difference on a properly built performance engine.
Old Aug 25, 2007 | 07:44 AM
428HIGHBOY's Avatar
428HIGHBOY
I know I have it advanced alot. It is to the point that it cranks over real slow when it is warm. This seems to be where it runs the best???
Old Aug 25, 2007 | 11:43 AM
"Beemer Nut"
If your dynamic compressions that high due to just the advanced cam your not going to run not alone start. Sounds like starter heat soak.
Granted ring gap will be tighter with less leak down your splitting hairs that only a leak down test will reveal.
Old Aug 25, 2007 | 10:28 PM
428HIGHBOY's Avatar
428HIGHBOY
I can retard the timing a bit and I dont have the slow start. It isnt the heat with the starter. It has to do with the heat and the timing. It is that I have it advanced that much. I am going to retard it a little bit. It just seems to run harder where it is at.
Old Aug 25, 2007 | 10:54 PM
"Beemer Nut"
Seems we have a crossfire three way conversation here, I replied about the cam to crank relationship 390 posted.
You will run harder at low end with more ignition advance to a point before your bucking plus detonation not alone hard starting problems. FE's like a lot of initial and total advance, tells ya something doesn't it about a wedge vs a more efficient combustion chamber design?
Old Aug 26, 2007 | 08:44 AM
blue68f100's Avatar
blue68f100
I run through first and secound and shift into third about 30' from the end.
Why are you shifting. If you watch the pulls on ESPN they are not speeding up as they go down the track, slow/fast and steady wins. The goal is to get to the finish line first, second is to have quickest time. Pick 1 gear and stay in it do not shift. As you go through the rounds the load gets heavier, so you may need to stay in 1st. Every time you shift you stop your momentium.
Old Aug 26, 2007 | 05:21 PM
428HIGHBOY's Avatar
428HIGHBOY
I think you are on the wrong path. I run mud drags not truck pulls. I run low range drive. I let the truck to all the shifting.
Old Aug 26, 2007 | 06:02 PM
blue68f100's Avatar
blue68f100
Yes drags are different than Pulls, my mistake. Speed is what get you through the mud faster.
Have you run any of the compression tests?
From what all that has been discussed, the pistons swap would be the greatest gain.
You may be able to boost compressions by only changing the pistons and transferring the rings to the new pistons. But you would have to examine the cylinder walls closely at the top. The higher compression may position the rings higher in the cylinders. I would probably be tempting to re-hone the walls and install new rings. I generally buy over size rings and custom fit my rings. Or move to the newer zero tension rings.
Old Aug 26, 2007 | 08:19 PM
"Beemer Nut"
The one thing in common is you must be fast and first every time.
Old Aug 26, 2007 | 09:06 PM
428HIGHBOY's Avatar
428HIGHBOY
The engine only has about 1500 miles on it. So ring wear shouldnt be an issue. When I had the machine work done, I told the machine shop that I wanted 10:1 to 9.5:1. When I wicked it up he had milled the tops of my pistons to bring the compression down to 9:1. And yes I was PISSED!!
He was on a kick about not being able to run on pump gas. I told him that I would run the premium. Damn chevy lovers!! I think he just wanted to give the chevys a chance.
Old Aug 26, 2007 | 11:03 PM
"Beemer Nut"
The hp loss by a half piont isn't that much, I would of been pisssed and made then replace the buckets. This is the reason why I do my own work as I trust no one and why I own a lathe, Bridgeport mill, Tig and Mig.
Old Aug 27, 2007 | 08:22 PM
428HIGHBOY's Avatar
428HIGHBOY
I sure wish I had all those toys. So now that we are off of the compression topic, how about the cam? What can I do to get a fair amount of power and keep my 17" of vacuum?
Old Aug 27, 2007 | 08:54 PM
  #28
blue68f100's Avatar
blue68f100
Have your rings seated yet with 1500 mi? Oil consumption stopped?
There may be some cam timing changes that may help. Would be easier than changing the cam. You should talk to the mfg of the cam for those changes.
As for cam, we have determine that you may not have clearance for a higher lift. A roller cam open and close quicker than a hyd/flat tappet cam. As far as a which one, I haven't a clue. They have your hands tied with the stock class.
Old Aug 27, 2007 | 09:13 PM
  #29
Redtires019's Avatar
Redtires019
If you have the money I vote for the roller cam also. You can keep the same adv duration and lift. The roller can will have a much more aggressive ramp on it so it will open at the same point but get to full lift faster, hold full lift longer, and then drop back and close at the same point as your current cam.
Duration and lobe separation are the 2 things to watch for if you are trying to hold the same vacuume numbers. the lower the lobe separation angle, the more overlap you will have and the less vaccume at an idle. The same with increasing the duration. Lift is mostly free.
Old Aug 28, 2007 | 07:23 PM
  #30
428HIGHBOY's Avatar
428HIGHBOY
So now I have 110 deg seperation. If I was going to go with roller I could have a highrer lift and longer seperation with the same duration and have the same vacuum as long as the duation stays the same??
