Modular V10 (6.8l)
She won't start!
Old Aug 19, 2007 | 08:14 AM
tps0424's Avatar
tps0424
She won't start!
The engine turns fine and when you turn the key, you can hear the fuel pump for a second but, I don't know if that's long enough. I'm stuck at a campground in Virginia 650 miles from home.
I'm on the camp store computer and will check back later.
I did call Coachnet (like AAA for RVs) at 5:00am and they said I'd have to wait until tomorrow for them to contact a Ford dealer.
I need to be at work in Newport, RI tomorrow. Any ideas why she won't start???
Old Aug 19, 2007 | 10:41 AM
hydro_37's Avatar
hydro_37
Pull the fuel filter and make sure it is not clogged.
Old Aug 19, 2007 | 03:04 PM
biz4two's Avatar
biz4two
Arrow
Could be fuel related, so try this...
When the engine is turning over, make sure to have your foot pressing the "go-pedal" about half way down. See if that helps...
biz
Old Aug 20, 2007 | 10:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'd also check to see if you have spark - pull a COP, stick a small screwdriver in the end and place near a good ground. Crank and see if you get a spark. If you do not, there's no power to the PCM, or no cam/crank sensor signal.
Old Aug 21, 2007 | 06:41 PM
tps0424's Avatar
tps0424
It's going strong again!
It turned out to be a loose ground to the fuel pump. Everything is great now and we made it home. Thanks to all who had suggestions. I knew I could count on you guys for help!!!
Old Aug 21, 2007 | 10:48 PM
biz4two's Avatar
biz4two
Arrow
GREAT to hear! Thanks for posting the fix...
biz
