can your wire sizes be too big?
Old Aug 18, 2007 | 08:31 PM
71dusterdan's Avatar
71dusterdan
i had a hard start problem when hot with my 89, so i replaced the battery cables. i made new ones out of 2 gauge, the truck came with 4 gauge. is this okay or do i look forward to resistance problems later. it more than cured my hard start problem. just don't want later problems. thanks. Dan
Old Aug 18, 2007 | 10:25 PM
mhg's Avatar
mhg
the only way you get to big is if you can not
get it thru the opening to where you need it to go
when I replace mine I go for single O welding wire
comercial crimper tool to install the ends
Old Aug 19, 2007 | 10:02 AM
projectSHO89's Avatar
projectSHO89
On an application like this, overkill is far better than stock or under kill as long as you can still move route the cables.
Don't worry, you've now got a better than stock cable set.
Steve
NICKSAN
Mar 31, 2017 01:42 PM
Tdracer344
Nov 12, 2016 01:48 PM
2003fatboy
Aug 23, 2016 11:27 AM
regidog
Apr 5, 2016 10:09 PM
skeneguy
Feb 12, 2007 10:48 PM
